![]() | #1 | ||
Posts: 31 Thanks: 1 Trader Rating: 0 ![]() | Noisy twinair idle 0.9 2013 Hi fellow twinair owners. My twinair engine is extremely rattly at idle, but if you just just very lightly touch the throttle is stops and goes silent, drives fine, runs well, it’s just quite a rattle it gives off and is quite audiable in the staff multi story car park. Is it just the twinair unit I’m guessing as slightly touching the throttle stops it Thanks all
![]() | #2 | ||
Posts: 26,429 Thanks: 1014 Trader Rating: 0 ![]() | Re: Noisy twinair idle 0.9 2013 Hi fellow twinair owners. My twinair engine is extremely rattly at idle, but if you just just very lightly touch the throttle is stops and goes silent, drives fine, runs well, it’s just quite a rattle it gives off and is quite audiable in the staff multi story car park. Is it just the twinair unit I’m guessing as slightly touching the throttle stops it Thanks all ![]() depressing the clutch pedal.. or switching on the aircon.. make any great change to it..?? Charlie - 2012 TA - Oxford
![]() | #3 | ||
Posts: 31 Thanks: 1 Trader Rating: 0 ![]() | So the noisy rattle is only when cold, after the initial cold start and when the revs start to drop down, so around 1200 rpm, and then at idle until the engine is driven. Yeah so after the car has warmed up it’s silent, no rattle at all. Dipping the clutch makes no difference but switching on the a/c or heated rear window makes a slight difference with the load! Thanks for the reply! Ash, Essex
![]() | #4 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: Noisy twinair idle 0.9 2013 Hi Ash, did you get to the bottom of this in the end? My wife's 500 TA seems to have developed the same rattle. It goes when you switch off the AC ![]() Thanks Willem
![]() | #5 |
__________________ Cardiff / Oxford |
![]() | #6 |
![]() | Re: Noisy twinair idle 0.9 2013 Does your rattle sound like its in the car or coming from the engine bay? Also does the noise speed up and slow down with the engine speed or does it speed up and slow down with the Fan speed in the cabin?
__________________ Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers can’t be wrong ![]() And now the owner of a shiny new PuntoHowTo Drivetribe |
![]() | #7 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: Noisy twinair idle 0.9 2013 @AndyRKett Hi there thanks for your reply, the sounds is coming from the engine bay and with the AC on any speed and you can hear it only whilst stationary. It will go if you switch the AC off, rev a little or press the clutch. Once moving the sound is not there. thanks for your input
![]() | #8 |
![]() | Re: Noisy twinair idle 0.9 2013 Could be the clutch on the air/con compressor is slipping or the belt feeding the compressor and alternator. Do you know if the belt has been changed at any time?
![]() | #9 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: Noisy twinair idle 0.9 2013 All belts are still original from new, also have an oil leak and noticed that this is related to the timing chain cover according to some posts on this forum. At 110k it might be worth replacing all belts in that case and reseal the timing chain cover.
![]() | austenw90 | Punto (2012+) | 0 | 28-10-2017 19:21 |
![]() | p6baseunit | 500 | 4 | 18-01-2017 16:35 |
Panda 2012+ My black 2013 Panda Sempre Twinair Turbo 85 | TheR | Members Motors | 17 | 11-03-2016 13:56 |
Panda 2012+ 2013 Panda 4X4 TwinAir | deeyup | Members Motors | 91 | 19-10-2014 17:59 |
![]() | mitchellinman | Stilo | 4 | 14-03-2006 02:08 |
