Old 24-02-2016   #1
HELP check running lights HELP
HELP.....
Can someone point me in right direction....
2012 punto
when car is running during the day ie no lights on (only day time running lights)
everything is fine
However come night time switch on lights and within a few seconds or minutes get error triangle and check running lights
Now heres the bit i dont understand
i checked all lamps/bulbs all okay.
apart from rear passenger led which was dim(see other threads)
so replaced entire cluster bingo no more dim leds on passenger side.......
but then i get error triangle flash up check running lights
What is going on ......
do i need to get ecu cleared of codes? is there a way of forcing a manual reset?
the only day running lights on the car are in the front head lamps and they seem fine....if they were faulty or on their way out surely it would come up on dash with out head lamps on ?
please help
derbyshire gp is offline Reply With Quote Quote
Old 25-02-2016   #2
varesecrazy has donated!
Quote Originally Posted by derbyshire gp View Post
HELP.....
2012 punto
everything is fine
please help
Sounds odd. Normally poor connection.etc
as its monitoring whats being used..eg.led bulbs
as youve fitted a different light unit a relearn could do the trick..look in 500 section it maybe theyve had similar before..?
Charlie
Likes derbyshire gp liked this post
Old 25-02-2016   #3
Re: HELP check running lights HELP
Ha Ha
funnily enough sorted
thanks varescrazy for input
Went out to car this morning started up and left running whilst scraping ice off windows
put lights on yellow triangle as usual
got in car to drive and error gone so must have re-calibrated itself
Old 28-02-2016   #4
Nope not sorted
Still get error
Seems to be okay if car has been running for 20/30 seconds or so and then put lights on.
But if lights get put on straight away error check running lights
Old 29-02-2016   #5
Moderator
Andy Monty's Avatar
Andy Monty has donated!
with ignition off turn on parking lights both front ones working?
Massive gash
Just a little touch up
Old 01-03-2016   #6
Parking lights ok both front on and both rear LEDs
However didn't get an error message?
Sent from my iPhone using FIAT Forum
It's not modified....it's a Punto POP
but it is probably the most improved pop in the uk
Old 01-03-2016   #7
Hey,
I'm new to this community, I've upgraded from a Mk2a.
I bought it and got it yesterday and noticed the same error message on the way home. Bear in mind this is at 7pm-ish so the lights were on.
Now my girlfriend noticed that every time the error message comes on, is when the brake pedal is pressed.
Not sure if this helps, but I thought I'd chime in!
I need to go back to the dealer next week to pick up my plippy key. So I'll ask then!
JamHew is offline Reply With Quote Quote
Old 01-03-2016   #8
Quote Originally Posted by JamHew View Post
Hey,
Hi, and welcome,
probably a blown brake light bulb..
or the wrong wattage fitted maybe a poor connection..,
Charlie
Old 01-03-2016   #9
I've checked the brake lights, they're all working fine!
Very confused!
Old 01-03-2016   #10
Moderator
Andy Monty's Avatar
Very confused!
replace both bulbs (the 21/5w split filament ones )
ensure they are in correctly as with force you can get them 180 degrees out of kilter
what i think has happened is brake filament has gone and the broken bit has dropped and bridged to the tail light filament...
Massive gash
Old 01-03-2016   #11
Quote Originally Posted by Andy Monty View Post
Okay thanks, I'll investigate in the morning!
Old 03-03-2016   #12
brake light bulbs dont appear to be the issue as above its just a single filament bulb so changed it any way.
still got error
switched off and on severeal times turned ignition on and off severeal times now error gone
hope it lasts
Old 03-03-2016   #13
No still error
Old 06-03-2016   #14
well i think the only solution is to replace every bulb
seems to be intermittent
so will be a process of elimination
Old 14-03-2017   #15
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Got the yellow lightbulb warning lamp and a check running lights error message on our 2012 Punto Twinair.
It seems to be as soon as you turn on the lights - not related to breaking.
All the lights seem fine when walking round the car.
Reading other GP threads there are more than 1 tail light bulb in the rear clusters.
So my question on the 2012 punto how many tail light bulbs should I see in the rear clusters?
I only see 1 at the top of the cluster.
Thanks all.
Louie Bee is offline Reply With Quote Quote
(T) Check Running Lights Ffoxy Grande Punto 25 07-08-2020 22:46
(T) Check running lights ahmett 500 4 18-05-2015 17:38
(T) Check Running Lights? Mazie Grande Punto 6 03-11-2011 20:10
(T) Check running lights payney1 Grande Punto 8 07-08-2010 11:13
(T) Check Running lights GlasgowPunto Grande Punto 3 23-03-2010 21:47
