FIAT Auto Specialist Team
Thread Tools
Old 09-10-2015   #1
towbar fitting Punto Easy 2012
Hi all.
Anyone got a thread link for fitting a towbar and the bypass electrics to a Punto Easy. no reversing sensors. Really wondering where people took a live feed from for the relay. Also how did you splice the wiring into the harness.
3PBerlinetta is offline Reply With Quote Quote
Old 11-10-2015   #2
varesecrazy has donated!
Re: towbar fitting Punto Easy 2012
pretty quiet in this section,
I would SEARCH the GP , and TECH sections
it's the CANBUS control element that needs extra thought / care..,
Charlie
Old 12-10-2015   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
see gp guides,.
YOU MUST USE A 7 WAY MULTIPLEX RELAY DUE TO THE PULSED LED SIGNAL FOR THE TAIL LIGHTS!
colours are different tho if i get chance this week i will pull the carpet back on mine and check but all could be found with a multi meter
as for live feed remove passenger *(uk) door foot trim pull off bonnet handle remove side kick trim theres a BIG live cable under there which is used on high spec evos for the boot fuse box i tapped into that
Thanks varesecrazy thanked for this post
Massive gash
Just a little touch up
Old 13-10-2015   #4
Thanks very much. Andy Monty Is the big red cable a permanent live? Do you know if all the wires come down one side of the boot? I have the 7 way bypass relay. I just wish to know the best way to tap into the harness. Current thoughts are bare a few mm of the wire and solder in. anyone have a wiring diagram as PDF or similar for colours?
Old 14-10-2015   #5
Moderator
Andy Monty's Avatar
I soldered mine... I run 2 cores to the right hand side for right indicator and side light
I was all smug walking to my evo till I noticed fiat had changed the colours
Yes the wire is constantly live I fused it there
Massive gash
Old 14-10-2015   #6
wonderful, Thank you
Thread Tools
(G) AUX in Punto 2012 Easy supereeg Punto (2012+) 36 2 Weeks Ago 20:11
(T) Fitting towbar to punto dc2014 Punto (Mk2/2b) 14 11-06-2014 08:53
Punto 2012+ Punto 2012 Easy 1.4 77CV Blue Mkala Members Motors 0 14-12-2013 09:00
Panda 2012+ 2012 1.2 Easy catnash Members Motors 7 04-12-2012 04:00
