Old 05-10-2014   #1
'13 Punto MultiAir 105
austenw90's Avatar
austenw90 has donated!
Stop & Start doesn't seem to work
I picked up my 2013 Punto yesterday from a main dealer and drove it home about 150 miles. I travelled to get the spec I wanted.
One thing I've found is that the stop and start function doesn't seem to work. I've switched it off and back on. It says it's "connected" but no matter what it doesn't work. I understand it doesn't function when there is too much load but I've tried it with all electrical things turned off but still nothing. I also know how it operates from driving another Punto with Stop/start.
Thanks for any advice.
austenw90 is offline Reply With Quote Quote
Old 05-10-2014   #2
Switzerland
Re: Stop & Start doesn't seem to work
Hello
Please read this section and the evo section or your manual, they are a lot - a lot- of condition for start and stop to function.
With a new car, it can take some times to activate.
Keep us informed when your car has more miles and days
Likes JTD_Liam liked this post
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 06-10-2014   #3
varesecrazy has donated!
Main Dealer is the clue there, chances are it's been sat unused for a while, the battery will need a fair bit of regular use to get back full function - if at all -,
my 2013 was in group stock, only worked regularly after 2 hour m-way journeys,
laid it up for 10 days while I flew to Italy last month, hasn't worked since..
I suspect a replacement battery will sort it -- get in quick -- while the warranty is still covering it,
Charlie
Likes Super Uwe liked this post
Old 06-10-2014   #4
austenw90's Avatar
Thanks both. Will the warranty cover a replacement battery?
I can't go back to the dealer I bought it from. They are in Wolverhampton and I'm in Southampton.
It's not a feature that I'm massively fussed about but things annoy me if they are there but don't work!
Likelihood is it's been doing too many short drives. 9100 miles on an 18 month old car registered to the dealer.
Old 07-10-2014   #5
My new car is the same, bloody annoying
I will be speaking to the dealer... I expect stuff to work from the get go and if the battery is not 100% charged then I will kick off until it is right.
Stuff like this makes me mad!
Aikidoamigo is offline Reply With Quote Quote
Old 07-10-2014   #6
Switzerland
To understand why it is not working, please indicate if you have original battery or not.
If you have an OBD reader, check ECU/body computers faults.
If you have a multimeter, post voltage of battery after a night staying, and when engine at idle, all off (fan at 0 or 1, no windows heater, no lights except DRL, no radio, etc)
Old 08-10-2014   #7
austenw90's Avatar
I've booked with my local dealer in a few weeks time.
I've been driving with the radio off, heater fan as low as possible (probably doesn't help that this is climate control), lights off where possible and day lights off. Hopefully this may help the battery re-charge? If that's what it needs.
Old 08-10-2014   #8
austenw90's Avatar
Is there a particular type of charger that needs to be used for stop start batteries?
Old 08-10-2014   #9
Switzerland
When you drive you can use all electric devices you want. Its just at idle to not make a false measure, because at low rpm alternator output is low.
Unless you make only short trips, the full battery charge should be reached.
No special charger is needed, base technologie is the same. Its just number of cycles is higher.
Prefer a recent elecrronic charger that do not boil electrolyt with poor end of charge voltage detection
Thanks austenw90 thanked for this post
Old 08-10-2014   #10
Super Uwe has donated!
I have the same problem as the OP, our 62 plate 1.4 Easy's S/S hasn't worked for about three or four days now.
It has stopped working about three or four times before as well, and then started working again (typically after a couple of successive longer journeys).
Similar situation as well; the car only did about 1500 miles in the 12 months before I purchased it in August (it now has 11500 miles on the clock).
Also, although we do around 1000 miles per month, a lot of the journeys are quite short. So really, I don't think much will change in this respect.
People have recommended purchasing one of the ctek chargers, so I might do that this winter (there are several threads with specific charger details on the 500 section).
I can't honestly say I care too much though. I'd much rather the system didn't kick in if there is a suggestion the battery is lacking in charge!
Likes JTD_Liam, austenw90 liked this post
Had a 500, then a Panda, then a Punto, wife had another 500...now a Fiesta
Super Uwe is offline Reply With Quote Quote
Old 08-10-2014   #11
austenw90's Avatar
Quote Originally Posted by Super Uwe View Post
So are the Ctek chargers on Amazon suitable?
Like this one:
Obviously the cheaper the better.
Thanks for all the input.
Old 08-10-2014   #12
Switzerland
This charger looks really good.
Output current is a bit low - at 5amp it can take 12 hour to fully charge a battery, but with microprocessor and advanced modes it should perfectly charge your battery.
But - in my opinion it is not interessant to spend this money in a charger just for the start and stop... Even if you have trips that are good for S&S, it will take years to save this amount in petrol.
And this is about 50% of the cost of a new battery.
On my car, it works, unfortunately. I have to disable it constantly. On my wife car (same model, 3 month younger car) it does not work at all. And happy
A mechanic told me you can remove the connector of the sensor on the battery. After, S&S re-learn parameters and re-works ! But never tried, but I think you can't break something...
Old 08-10-2014   #13
austenw90's Avatar
Quote Originally Posted by Mkala View Post
Thanks Mkala. Any thoughts on these? I could leave this plugged into OBD port all day...
Old 09-10-2014   #14
Switzerland
You welcome
This mini solar panel ? Useless for most people.
It can only be useful if you dont use your car often, one or twice a month, or less.
If you use your car frequently, it's completely useless. Why ? The panel output can be - my guess - 5 watts.
Your alternator can output 1000 - 1200 watts (less at idle). So power of panel is negligible.
The only case is for car's not use for long time, this permit to keep battery charged to avoid sulfation. But it has to be more powerful that battery auto-discharge and car's constant consumption.
Don't twist your mind for S&S, try to remove the little connector or the battery to "reset" or start a re-learn.
Old 10-10-2014   #15
austenw90's Avatar
You welcome
Thanks. My S&S started working yesterday on both journeys I took. It didn't this morning but I was tinkering with the radio last night for a while which probably didn't help the battery. It has a DAB antenna hooked up to the standard head unit (all by Fiat) but is a bit rubbish really. The head unit doesn't seem to be designed for this.
I do about 8 miles each way to work Monday to Friday so the car is only really just hot when I turn it off.
Maybe a decent run is in order this weekend.
(T) start&stop doesn't work sablade 500 50 27-02-2014 13:20
(T) New Panda 4x4 TA B&M doesn't work vkent Panda (2012+) 8 23-09-2013 10:23
(G) Start &Stop TommyBrown2805 500 7 29-01-2013 11:29
(T) Start&Stop in stop-and-go traffic Mondaugen 500 63 17-10-2011 08:07
Blue & Me doesn't work anymore !?! nokiwi Blue and Me 7 25-05-2009 01:13
