Thread Tools
Old 16-12-2016   #91
Quote Originally Posted by rkt2003 View Post
Yes just undo the screws then give it a tug to pull it from the bodywork to reveal the connector to the light fitting then gently release the connector ,when refitting re connect everything in reverse ,it really is a five minute job and you will have job satisfaction and some spare money for Christmas
I will get onto that, had the misting problem as mentioned earlier in the post, seems pretty common. Thanks for the reply!
Likes rkt2003 liked this post
Statto1505 is offline Reply With Quote Quote
Old 16-12-2016   #92
Fiat/Abarth (17)
rkt2003's Avatar
rkt2003 has donated!
Guess Next Champion
Re: LED Tail Lights
Quote Originally Posted by Statto1505 View Post
My little tip is whilst waiting for your new tail light to arrive take the old one out and put back in again then you will know where everything goes when the new one arrives
Abarth 500 Competizione inc limited Slip Differential ,Koni suspension ,Black Leather Sabelt Seats Carbon Fibre Seat Backs,Record Monza” exhaust , fixed 4-piston calipers by Brembo, Electric sunroof, 17" Supersport Matt alloys, 7 inch entertainment screen with built in sat nav via Tom Tom,Dr Dre Beats audio with sub , Gara white,
rkt2003 is offline Reply With Quote Quote
Old 18-12-2016   #93
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: LED Tail Lights
you can almost swap them over with one hand (well i was holding the camera)
Massive gash
Just a little touch up
Old 18-12-2016   #94
Moderator
Andy Monty's Avatar
Re: LED Tail Lights
Hi my 63 plate punto has just failed its first mot with this same problem, near side led dim. Main dealer in Hull has said £130 for the light. Is it easy to fit this yourself?
Many thanks
just ensure you get the correct one:
https://www.shop4parts.co.uk/?name=s..._8v_Rear_Lamps
oh and Donate to the running of the fiat forum every £ helps you get access to our members offers section and you can then get a 10% discount code for shop4parts
Massive gash
Old 18-12-2016   #95
Super Uwe has donated!
Re: LED Tail Lights
Many thanks
Hi Statto1505,
As everyone else has said, it's an absolute doddle to fit the light yourself if you have to buy it. Please, PLEASE don't hand your money over to the dealer!!
However, have you tried hitting the bottom of the base at all, kind of roughly where the bottom of the two screws is holding the unit in place? I know that sounds completely bonkers, but genuinely it does work from time to time! Mine has been behaving itself for a good few weeks now...you can see I have posted in here several times over the past 18 months
Otherwise bahamutzeta's excellent post in this thread (post 64) is another option to try out.
It's certainly possible you may not need to shell out any money at all if either of those solutions work.
Had a 500, then a Panda, then a Punto, wife had another 500...now a Fiesta
Super Uwe is offline Reply With Quote Quote
Old 28-04-2017   #96
Croatia
Hi there!
I have problem with pumto evvo 2010 rear light... Sometimes glow ok sometimes as from picture
matija0evo is offline Reply With Quote Quote
Old 19-05-2017   #97
Croatia
Re: LED Tail Lights
Any help??? Yesterday i wash car... left and right side didnt work... and faliure show up on dash.....Today i unscrew bolts and disconect/connect jacks... Right LED glow normaly... Left one glow with 20% then 100% from time to time.... Is is problem with connector or with led line???
Turning lights and stop lights work normaly
Old 16-01-2018   #98
Re: LED Tail Lights
Hi all,
I recently had this problem on my 2013 (63) Punto GBT. After visiting a number of vehicle specialists and electricians for their advice they came to the conclusion that it was due to the moisture build up within the cluster, which I understand is a common problem.
I decided to take the problem into my own hands. I removed the unit from the vehicle and dried it off with a towel completely. I then began to dry the unit out with a hair dryer, even removing the bulb mount and drying the inside of the unit out. I progressed to seal the unit with electrical tape to ensure no water/moisture could get inside. When fitting the cluster back onto the vehicle I also applied a few layers of electrical tape to the connections.
This seems to have resolved the problem, fingers crossed it stays like this.
I hope that this helps!
Likes Super Uwe liked this post
dannhamiltonn is offline Reply With Quote Quote
Old 16-01-2018   #99
Re: LED Tail Lights
Quote Originally Posted by dannhamiltonn View Post
Hi all,
Yep, there are a few "fixes" which will all work to a certain degree!
Good news that it's sorted.
Old 16-01-2018   #100
varesecrazy has donated!
Re: LED Tail Lights
Sounds as if the lamp to bedy seals are marginal..
luckily mine is fine..
having not seen a jetwash since the dealership numpties jet washed the mats(may just be why the windows kept misting..)
Old 13-04-2018   #101
Re: LED Tail Lights
Quote Originally Posted by matija0evo View Post
Hi, I have a 62 plate 1.2 punto easy. The same left hand side led tail went very dim. It has now been ok for the last 2 months after I hopefully found a cure. I took the unit from the car, and also unscrewed the bulb holder from the unit. There is a circuit board inline with the led which can be seen inside. So I drilled a small hole through the back plastic in line with the screw holding the circuit board in. Then after taking the screw out, the circuit board swings out. I only re-plugged the edge connectors and its has worked ok since. Worth a try as it cost nothing and just leaves a small hole in the back of the unit which makes no different to it.
Likes Pugglt Auld Jock, derbyshire gp liked this post
DavidMcg is offline Reply With Quote Quote
Old 15-04-2018   #102
Hi all,
Has this lasted?
Old 07-06-2018   #103
Serbia
Re: LED Tail Lights
Sory on my bad english.On my Punto 2012 yesterday it happened that the left led was barely shining. After I took unit from car, I tried to remove moisture with a hair dryer, and it works, the led now works normally. Thanks for the advice, I saved 50 euros for how much they are selling us on car scrap for the whole last unit
dejajankovic is offline Reply With Quote Quote
Old 07-06-2018   #104
Re: LED Tail Lights
Interesting that its always seems to be the left hand side cluster that goes
Likes Pugglt Auld Jock liked this post
It's not modified....it's a Punto POP
but it is probably the most improved pop in the uk
derbyshire gp is offline Reply With Quote Quote
Old 26-06-2018   #105
South Africa
Re: LED Tail Lights
Hello Everyone
Registered just so I could give feedabck.
I have a Fiat Punto Easy 1.4 purchased late 2012 which also had the left led on the back light seemingly go dead.
Mine's been dim for over a year and recently seemed to be completely dead. Yesterday as per reading this entire post I removed the fixture, disconnected the bulbs from the fixture and put them aside.
I then took a hairdryer and blew hot air over the back of the pcb which you can just see sort of in the middle of the fixture and then at the top on the led's moving the hair dryer up and down for a few minutes.
My light is now working again Full brightness, extremely happy. Just becareful I did slightly melt some of the plastic inside slightly (Don't let the hair dryer blow on one point for too long) but you would never notice once fixture back in place. Oh I did let it cool off as the fixture was quite hot to the touch when I was done (Hence melting ). I'm wondering now if there is a poor soldering job on the pcb as my light fixture unit had no damp or moisture. I live in South Africa which has predominately nice warm and sunny weather.
AnoSA is offline Reply With Quote Quote
Thread Tools
(S) Angel eyes or led rear tail lights for our panda? ibiza1_0 Panda 35 21-02-2011 02:21
(S) Black LED tail lights? lonepilgrim Grande Punto 11 08-06-2009 12:25
(S) Fiat Bravo LED rear tail lights ausritmo Bravo 1 04-02-2009 21:50
