General AUX in Punto 2012 Easy
@sudhanR It seems you have a different model and I don't think I can help you with that. Mine looks like that:
imgres
Hi - I've got an F263 EUR HU in my Fiat. I've connected a yellow ISO to 3.5mm jack but couldn't get the AUX option. My pin layout was identical to yours so I connected the D IN and D OUT pins - and voila it gave me the AUX option when pressing the Media button - but still no sound :( Any suggestions?
VERY quiet in here:eek:
SEARCH / ask in GP section or the ICE section,
Charlie
Hi guys! I've been reading all the pages, but I am not sure if it will work on my radio. I bought a Fiat Punto Easy S&S 1.2 2013 with the following radio:
ytxx4kg-jpg.85908
Is it possible for me to install the AUX cable in the back of HU? If so, what specific cable should I buy? Can I use the cable to connect a Bluetooth Kit in order to make phone calls?
Thanks for your help :)
ytxx4kg-jpg.85908
I would've thought that you have Blue&Me, in which case, you should have a USB socket, which will allow you to put music on a memory stick, and listen to it from that, as well as being able to make phone calls.
ytxx4kg-jpg.85908
I would've thought that you have Blue&Me, in which case, you should have a USB socket, which will allow you to put music on a memory stick, and listen to it from that.
Why do you say it has Blue&Me? I'm almost sure it doesn't. How can I confirm?
I think it was made standard when they tweaked the Grande Punto in 2008, so I don't imagine they would've deleted it for the facelift version. Have you tried looking for a USB socket in the glovebox?
I bought the car but it still is on the salesman garage and I only have access to it in the next week, so I can't confirm right now if it has a USB socket in the glovebox. But I am almost sure it doesn't have the Blue&Me functionality (if it had Blue&Me, shouldn't it had a dedicated button on the steering wheel?)
Do you remember seeing a button on the steering wheel which looks like it's got the Microsoft Windows logo on it?
Hi
Do you have another link for this cable?
I've also got a 2012 Punto with Delphi 199FL stereo.
I've tried 2 different cables but it still says no source.
Hope you can help
Hi
Punto Evo 2011, Delphi F199FL EUR, no Blue&Me
I've plugged blue connector into the left side of the radio connector and display still shows no source avilable. I have no idea what to do
