FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->LED Headlight<!-- google_ad_section_end -->
LED Headlight
Published by AllCity
01-05-2016
Difficulty Level: 1
User Rated:Unrated
Thumbs up LED Headlight
Ok is led from AliExpress
one lamp use 1.9A on 14v
Ok installation is easy just remove old lamp and install it...
Testing....
Old 03-05-2016   #1
Israel
Re: LED Headlight
from driver side need to unmout fuse box on 3 bolts
AllCity is offline Reply With Quote Quote
Old 07-05-2016   #2
Hungary
Re: LED Headlight
Why did the cover of the lamp melt?
kido resuri is offline Reply With Quote Quote
Old 08-05-2016   #3
Israel
Re: LED Headlight
Is not melt is just black seal like raw rubber😊
Old 08-05-2016   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: LED Headlight
This modification is illegal for rod use in most countries. Looking at the lght pattern you can see why.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 13-05-2016   #5
Israel
Re: LED Headlight
Old 22-11-2016   #6
Trader Rating: 10
dave has donated!
Re: LED Headlight
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
got a link to official documentation on this please?
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 22-11-2016   #7
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: LED Headlight
Quote Originally Posted by dave View Post
Yes,
The Road Vehicle Lighting Regulations
http://www.legislation.gov.uk/uksi/1...lation/14/made
is the basic one which says that the bulb must be appoved and marked ( "E" or BS mark). Fundamentally you must fit the same type of bulb e.g. H4 as was used in the light when it was approved. You can't get a approved LED replacement for a filamment lamp. Part of it is basic physics, the reflector was designed to work with a small, light source that radiates in all directions and is placed in exactly the right place in the reflector. LEDs can be small but they emit light over a limited angle and those that produce light levels high enough for a headlight are not small and many are needed so the source is much larger than a filament and cannot be in the right position.
Robert G8RPI.
Old 22-11-2016   #8
Trader Rating: 10
dave has donated!
Re: LED Headlight
Yes,
Robert G8RPI.
that dont confirm it like what the hid info does, there are many leds on the market some have many smds some only have 2 or 4. is there no docment that clearly states the fitting of leds? after all people have been using them for side lights for many years and ive yet to here of anyone getting into trouble with the police for them. I was going to put led headlight bulbs on my xmas list.
Old 22-11-2016   #9
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: LED Headlight
I think it is very clear. It states any replacement bulbs must be E marked. There are no E marked LED replacements for halogen headlamp bulbs. I've not found any "simple" guidance, but rememeber it's only the courts that can make the final determination. I'm not a lawer, but do deal with technical legislation as part of my "day job" so am very certain of the position, there are no legal LED replacements. Note that NONE of the major manufacturers offer LED replacement headlamp bulbs.
Robert G8RPI.
Old 23-11-2016   #10
Trader Rating: 10
dave has donated!
Re: LED Headlight
Robert G8RPI.
that's a good point but they never made led gu10s when they first came out though only started making them when no one was buying their standard bulbs any more. part of me thinks they may not want us to use bulbs that last so much longer
Old 23-11-2016   #11
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: LED Headlight
Oh they want to make them. Osram say they are working on it, see
https://www.osram.com/osram_com/tool...ting/index.jsp
under "Why are exterior applications allowed off-road only?"
Robert G8RPI.
Old 23-11-2016   #12
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: LED Headlight
Just had another thought,
If we still used sealed beam headlights it would be easy to make and approve an LED replacement
I guess the market is a bit small now.
Robert G8RPI.
P.S. Just searched and they are available!
http://www.grote.com/family/led-sealed-beam-headlights/
So Classic Fiats have a legal option
Old 26-06-2018   #13
Re: LED Headlight
First off - I detest the dazzle we get these days from so many car headlights. I also detest not being able to properly see where I'm going.
The latest LED bulbs have at least as good focus as the old halogens and probably better than a super bright (short life) halogen. While being technically not road legal they will be very unlikely to fail an MOT** or give an officer of the law any concern about the bulbs. A blown halogen headlight will quickly have you pulled over, apart from being a menace in bad weather.
That said, buy cheap and you risk being a danger to others and yourself. Good quality LEDs are not cheap especially in H4 format. They have emitters the same size as the halogen filament so not surprisingly they give the same beam pattern.
** UK MoT test is concerned that fitted lamps must work. If any don't work it's a fail. The headlamp dip beam must have a correct pattern with no scatter at the edges. Main beam can do what it likes as it's not tested for pattern other than simply lighting up. The tester does not pull any bulbs to check the CE status.
DaveMcT is offline Reply With Quote Quote
Old 26-06-2018   #14
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: LED Headlight
Aftermarket LED replacements for halogen bulbs will nver have "good focus" or correct beam patterns. As of May 2018 the UK MOT includes a specfic check for headlight conversions so they are now much more likely to result in an MOT failure.
Robert G8RPI
Comment
Search this Guide:
(T) Headlight bulb spring clips and other headlight related woes. Mark0 Panda (Classic) 11 15-11-2014 15:58
(S) They have arrived - Dark headlight LED DRL Rappidpie Bravo 7 06-03-2013 09:26
WANTED: polyeliptical headlight headlight connectors Ant Wells FIAT Boo Archives 0 16-05-2011 02:28
(S) black lexus lights (led/non led) Aid1987 Punto (Mk2/2b) 20 01-12-2006 17:09
