Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fuel Pump<!-- google_ad_section_end -->
Fuel Pump
Published by AllCity
13-02-2014
Difficulty Level: 1
User Rated:Unrated
Fuel Pump
Remove cover
Plastic nut tool (made in home first version )
Get one this in 2012 (magneti marelli)
Chenge top covers in new cover less
Now ok
Old filter
Link to original album
Thanks homeward thanked for this post
Likes Diwiak, s and b liked this post
Old 23-02-2014   #1
Burkina Faso (Upper Volta)
Re: Fuel Pump on Fiat Punto MK2
plastic fastener on top of pump often seize on and can go brittle with age
i poor a kettle of very hoy water over it before i commence to try and remove it
nice tool by the way allcity
s and b is offline Reply With Quote Quote
Old 24-02-2014   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi @AllCity and thanks for the guide
On any future guides you do, please could you use the Fiat Forum Gallery to upload the photos and then attach them to the guide. Ive changed this one for you already. It just means that the guide will work correctly on the fiat forum app and the forum wont be left with any missing pictures or dead links should the photos be removed from the hosing site in the future.
Thanks,
Alan
Likes homeward liked this post
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 01-06-2014   #3
update to tool needed to remove plastic locking ring
ive now failed twice with boiling water so gone on to think out of the box and so spend no money on fancy tools you will probably never use again as a home mechanic
get two pairs of mole grips securely fastened at 180%to each other on the metal boot floor
now with the aid of a helper one through tailgate one sat in back put pry bars on mole grips and in unison lever this ring off
some are so tight they still break so consider robbing a spare from your local friendly junkyard before starting
be aware fumes kill and dont make itchy scratchy sparks though just in case theres enough fuel/fumes to cause an explosion
Thanks Dark_Crusader thanked for this post
Old 26-02-2016   #4
Serbia
Many thanks for your detailed guide.
Here is nice video abt this topic:
aca is offline Reply With Quote Quote
Old 4 Weeks Ago   #5
Diwiak has donated!
Slovakia
Thanks. Any need to change filter insert separately??
Panda Plus(319) 1.2 69k EURO6 S&S Sicilia Orange
Punto(188) 1.2 8V 60k Rosso Vulcano
Diwiak is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Where is the fuel pump mk2 punto sbrown987 Punto (Mk2/2b) 6 05-04-2011 19:39
