The usual applies here, this is the process i went through removing and refitting the shaft
I personally take no responsibility to any damage to you - the property around you etc etc
The steering system is crucial to driving, should anything fail and you have an accident because you failed to install it correctly - i will not be responsible, your own work is your own work
Ensure all fixing are refitted correctly and suitable tightened or torqued up
I advise you read my process from start to finish to gain an understand who/where/what/why/when etc
With that bit out the way - LETS BEGIN!
