| Guide Tools | Search this Guide |
Published by red 25-04-2010 | ||||||
![]() | #1 | ||
Posts: 16 Thanks: 0 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop Thanks for the guide. Currently v2.3 of fiatecuscan has a bug and will not connect to any ECU's unless you pay for a license. v2.3.1 is due shortly to fix this issue, in the meantime has anyone got an old version such as v2.2.1 that they could send me?! Thanks ![]()
![]() | #2 | ||
Posts: 624 Thanks: 59 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop Here's V1.6 if that's any good. It's not really a zip. Rename it to exe. red
![]() | #3 | ||
Posts: 15 Thanks: 1 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop Hi; Could we do the same job with ELM327 interface, or VAG-COM KKL is necessary ? Thanks.
![]() | #4 | ||
Posts: 30 Thanks: 0 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop Hi, How do i establish which pins are 3 and 7 in order to solder a connection for the airbag reset? I have opened up the plug and i can see numbers 1, 8 , 9, 16 on the back i am guessing i can then work out pins 3 and 7 based on those? Just want to double check. Image of plug below Thanks,
![]() | #5 |
Posts: 83,655 Thanks: 1483 Trader Rating: 10 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop i see no image, try hosting it in your gallery on here
__________________ THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU |
![]() | #6 | ||
Posts: 164 Thanks: 16 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop great guide! can't believe i didn't find this when searching around for this info before! ![]() Cable I've just purchased is this one: cgi.ebay.co.uk/USB-VAG-COM-OBD-II-KKL-409-1-Diagnostic-Cable-Interface-/260673083796?pt=UK_Diagnostic_Tools_Equipment&hash =item3cb1539994#ht_3116wt_942
![]() | #7 |
Posts: 2,819 Thanks: 114 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop having problems connecting. trys to connect to the ecu and then it says requires registered version and it can only run in "simulation" mode. what does this mean? i thought i could still connect to wipe faults and find out which faults have been registered without paying 50euros to do that. am i doing something wrong? please help. |
![]() | #8 | ||
Posts: 164 Thanks: 16 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop which pins are 3 and 7?
![]() | #9 | ||
Posts: 16,995 Thanks: 854 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop Red means the pins on the EOBD lead. http://www.pikit.co.uk/peugeotmt/eob...explained.html shows loads about the EOBD system. Its an industry standard but can others confirm the info is all appropriate for Fiats. Pin 1 - Ignition positive Pin 2 - Pin 3 - Data Tacho / MUX network Late generation Pin 4 - Chassis ground Pin 5 - Chassis ground Pin 6 - Data Climate control/CAN High ('IS' Late generation) Pin 7 - K Line Data Engine management / Automatic gearbox management Pin 8 - Cooling fan control information / MUX network Late generation Pin 9 - Charge information Pin 10 - Pin 11 - Data BSI Pin 12 - K Line Data ABS/ESP/GEP/Suspension control Pin 13 - Data Air Bag/Headlight control Pin 14 - CAN Low('IS'.. Late generation) Pin 15 - Data Engine management Pin 16 - Battery positive I presume Yani means fit a switch to make or break the link between pins 3 and 7.
![]() | #10 | ||
Posts: 124 Thanks: 2 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop Hi, Am i correct in thinking the free version of this software allows tracking of voltages etc. alongside reading fault codes? I currently have an OBD-II reader but I keep getting the same errors even when replacing faulty sensors so voltage outputs could be useful Tony
![]() | #11 | ||
Posts: 16,995 Thanks: 854 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop The more complex stuff like airbags needs the fully paid version so probably the same with voltage traces. Software and cable requirements http://www.fiatecuscan.net/SupportedVehiclesList.aspx Main connector cable http://cgi.ebay.co.uk/ELM-327-USB-1-...item4154aec206 Adaptor cables for ABS, air bag, steering. http://cgi.ebay.co.uk/Airbag-ABS-P-S...item25628c5f46
![]() | #12 |
Posts: 2,848 Thanks: 113 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop right....i need to reset my airbag light and i am getting a bit confused.do i now need http://cgi.ebay.co.uk/VAG-USB-DIAGNO...item19c4ee9310 this and http://cgi.ebay.co.uk/Airbag-ABS-P-S...item25628c5f46 to make the light go off.I also need to get the software but just read i need to pay for the software,how much is this going to cost me.Sorry for all the questions just dont want to go wasting money i dont need to ! |
![]() | #13 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop My daughters 2001 1.2 8V Punto had the light come on. I read various threads on here that gave various tips of what did and didn't work. This is what worked for me. Downloaded the free version of the fiatecuscan software . Used a KKL VAG COM interface connector with the red adaptor cable from the fiat ecuscan adaptor leads. Identified the fault to the passenger airbag isolation switch and was then able to clear the fault to turn off the light. Great sevice and help from www dot gendan dot co dot uk I hope this helps others along the way. I don't think you can do it with the ELM 327 interface.
![]() | #14 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: How to read/reset ECU and airbag errors on Mk2 for a tenner and a laptop .........
Currently Active Users Viewing This Guide: 1 (0 members and 1 guests) | |
Guide | Guide Starter | Category | Comments | Last Post |
![]() | red | Punto (Mk2/2b) | 26 | 01-05-2010 11:04 |
![]() | hayabuas | Stilo | 19 | 29-06-2009 14:43 |
![]() | Rugbyplayer2 | Punto (Mk2/2b) | 5 | 28-06-2009 16:24 |
![]() | absys | Bravo / Brava | 0 | 16-07-2005 20:21 |
![]() | meirion | Punto (Mk2/2b) | 1 | 10-03-2004 23:57 |
