Technical My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do?
keepinitcriss
Colchester & East London
is it a certain brake fluid i must buy?.. its a Punto Sporting (02) and where can i find where to put it.. i am a Fiat rookie.. i just bort this car last week and loving it!
it will be dot 4 or better.
dot 4 is a specification not a brand.
you can go higher as in dot 5.1 but 4 is fine.
what are you doing that you need fluid?
is it losing fluid?
it must used up as the Warning light keeps flashing up on the dash, misc times and after i brake.. also i cant find where to put it??...
Your brake pads are low, if you change the pads it will raise the level in the brake res back up.
