newstor
- Oct 28, 2006
- 33
- 16
Hi folks,
I am currently experiencing yet another problem with my Fiat Punto 75 mk1.
When I start the car with cold engine revs go up to 2000 rpm and then right after so low (about 500 rpm) that the engine dies. If I start the car and right away accelerate keeping the revs between 1500-2000 for a couple of minutes then it will idle OK.
Occasionally the injection warning light switches ON after sometime driving, I don't have a clue if this is caused by the same root problem. My fuel consumption is also rather high, mix driving about 34mpg.
Has anyone experienced something similar?
So far I have replaced both lambda and coolant temperature sensor and it did not make any difference, any suggestion?
Thanks in advance!
/N
Thanks in advance!
/N
