MickM
Is there a DIY way of flashing out ECU fault codes on a Punto. Many other cars have this facility if you know how to do it. On Vauxhalls it's just a case of shorting a couple of pins on the diagnostic plug and reading the code which is flashed out using the ECU light. A friend of mine has the injector light illuminated on his N reg Punto but isn't sure why. The obvious thing is to take it to a dealer but they often overcharge even for a diagnostic readout...
