Old 15-04-2004   #16
as for selecting 1st and 2nd, check under the bonnet that the gear linkages r all greased in the 2 main points, on top of the box and near bulkhead. mine was rough and just greased the, sweet now!!..
punto chris is offline Reply With Quote Quote
Old 16-04-2004   #17
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: 1
JonnyBoy has donated!
My Punto's original gearbox was always a cow to get into first (it broke last year, unrelated to the shift; the final drive went and only turned one wheel [xx(]).
I fitted another 'box from a scrap car which feels exactly the same, i.e. hard to engage first gear. As far as I know it's a common fault - in fact, if you find a Mk1 Punto 55/60 with a decent shift into 1st, it's probably faulty!! :p
<font size="5"><font color="black">/</font id="black"> F <font color="black">/ </font id="black">I <font color="black">/</font id="black"> A <font color="black">/</font id="black"> T <font color="black">/</font id="black"></font id="size5">
<font color="navy">Punto 55SX</font id="navy">
JonnyBoy is offline Reply With Quote Quote
Old 17-04-2004   #18
i had that with my mrk1 but since ive had the seals done on the gearbox of me mk2 1st and secound are stiff but fiat say theres nothing wrong
chedda_2 is offline Reply With Quote Quote
Old 19-04-2004   #19
On my Italian market 1996. Punto 55 SX there is a cable for the clutch. I could post a pic if you're interested. It could be that the newer models, or models with diferent engines, have hydraulic, but this is a nice wire, with a funny plastic screw for ragulating tension.
Rubi is offline Reply With Quote Quote
Old 06-03-2006   #20
Re: sometimes hard to get in 1st and 2nd gear
It seems to happen with all puntos,dont worry about it tho.
nmt60 is offline Reply With Quote Quote
Old 09-03-2006   #21
Found this from website:---
Technical Issue: MK1 difficult 1st and 2nd gear engagement
A manual gearbox after 100,000km of abuse showed its sign of worn out. Normal gearbox lubricant can no longer adhere enough amount of oil to the synchronizer, therefore making dog teeth difficult to slide over each other, thus a difficult gear engagement.
As this happened to both cold and after warm up situation, it is so annoying that this problem must be fixed. But an overhaul gearbox is costly, option is to replace the lubricant with OBERON : F808 80W-90.
After that, customer found not only smooth 1st and 2nd gear engagement but also quieter cruising at 100km/hr and less vibration from the gear lever.
60sx is offline Reply With Quote Quote
Old 27-04-2008   #22
Hi
Do you know what the fiat garage actually did to your car?
WayneFletcher is offline Reply With Quote Quote
