Hi, supprisingly enough, something else has gone wrong....
Noticed a pool of water under the carpets running from the back seats to the drivers footwell.
I've just run a hose pipe on the outside of my MK2 and the water is coming from under the dash behind the pedals, looks to be a leak from the windscreen seal ouside. Does the whole dash need to be removed or just sealed from under the bonnet somewhere?
Plus I can't remove the drivers seat as there is no way of accessing the screws properly and with what??! Special tool?
Is it worth going to fiat? How much will they charge? Plus the mat (with the hard exterior and fluffy bottom) under the pedals running up to the top, is completely soaked and breaking apart. Will they replace this or just seal the hole?
I'm so depressed now. :bang:
