J jonesygpm New member Joined Nov 16, 2006 Messages 13 Points 5 Location stockport Feb 3, 2007 #1 does any1 know the standard fuel pressure on a punto 75 1.2 8v mpi? i have a fse valve and also need to know what to run the pressure at once that is on? cheers.
toad101 just can't get enough Parked in the garage Written a guide Joined Apr 21, 2006 Messages 5,077 Points 887 Location south east wales Feb 3, 2007 #2 is it the FSE power boost valve thats supposed to pick up 1.7 times faster? I thought these were already set at the right pressure, my bro tried one and all he noticed was the car used more fuel, hope you have better luck
davethetrike Patron member Joined Jun 1, 2006 Messages 714 Points 202 Feb 4, 2007 #3 jonesygpm said: does any1 know the standard fuel pressure on a punto 75 1.2 8v mpi? i have a fse valve and also need to know what to run the pressure at once that is on? cheers. Click to expand... multipoints 1.2 2.5 bar is the one with a return up to 98 3.5 bar is the one that has the return in the tank. 98 on 3.0 is the 16v All in the Haynes..
