justindublin
- Aug 30, 2006
- 61
- 26
Okay so i've had my FIAT 7 Months now and had problems after problem one after another until finally on Friday, on the M50, the engine went up in smoke.... ya know like, on fire!! So until tomorrow when the garage will begin to strip the engine and i'll find out what the dammage is i decided i'd make a list to share with some people the problems i've encountered in the run up to this moment. The list is 100% true and as i remember more items i'll add them. So here we go:
Trips to Garage: 23
Time in Garage to date: 39 Days
Problem: Fuel Injection Light
Resolve: ECU Fault, Remaped
Problem: Windescreen Wipers Stuck on Slow
Resolve: Motor Fault, Replaced
Problem: Rear Break-Lights Blown
Resolve: Wiring Replaced
Problem: Missing 6th Gear
Resolve: New Gearbox Fitted
Problem: Drivers Seat Jammed
Resolve: Lever Replaced
Problem: Noise from NEW Gearbox
Resolve: Gearbox Fitted Incorrectly, ANOTHER NEW Gearbox Fitted
Problem: Airbag Warning Light
Resolve: Fuse Replaced
Problem: Slipping Clutch
Resolve: New Clutch
Resolve: Injector Heads Replaced
Problem: Air Conditioning Not Working
Resolve: GAS Refilled
Problem: Passenger Headlight Blown
Resolve: Water Dammage, Headlight Replaced
Problem: CD Changer Jammed
Resolve: Reapired by Blaupunkt
Problem: Head Gasket Blown
Resolve: Skimmed
Problem: Break Fluid Warning Light
Resolve: New Container Fitted and Filled
Problem: Radiator Can Always On
Resolve: Temp Sensor Fault, Replaced
Problem: Keycode Light
Resolve: New Key Issued
Problem: Rev. Counter and Speed Clocks Blown
Resolve: Replaced Dash Clocks
Problem: Power Steering Disabled
Resolve: Torque Sensor Fault, Replaced
Problem: Exhaust Fell Off
Resolve: New Exhaust Fitted
Resolve: Sensor Fault
Problem: Central Locking Not Working
Resolve: New Laserline Alarm Fitted
Problem: Heating and Air Condition Not Working
Resolve: Yet to be Sorted
Problem: Engine Fire..... Yes like smoke and everything!!
Problem: Engine Fire..... Yes like flames and everything!!
Trips to Garage: 23
Resolve: New Clutch
Resolve: Skimmed
