Styling Punto mk II bumpers
fiat_cinq_driver
Near Brighton, United Kingdom.
At moment i have a punto mk II but it has the standard black bumpers on and its a blue car... where can i get the bumpers ot match the rest of the car???
Thanks in advacne,
Paul
Despite what the name says I now drive a punto!
do not sparay the oe bumpers they will look s**t, a number of members did this at puntomk2.co.uk and it did not turn out good!
But some aftermarket bits!
i have sprayed mine and they look great!! mind you my car is white!! i just used the plastic primer then the colour and then i used a clear laquer over the top to save chips and it did the job fine!! :D
mk2 punto in white, blue interior and more neons joining the car every day!! looking for ideas!!
im selling a full Carcept bodykt with sideskirts for 700 euros.it cost 1200 euros its the bizz excellent mind u mines a 2001 ferrari punto ud have to get sprayed
I have some sporting bumpers for sale, currently sprayed in black though this can be resprayed!
Will look a lot nicer having the proper bumpers rather than spraying the standard plastic ones :D
is your car in Car buyers guide? saw a punto with a kit in it today, - rang a bell
Met Cognac 99 Brava 100 HSX,
Yes - you can get 'Flat Black' - Black with no metallic pigment in it.
"Metallic" refers to the addition of a metal pigment (usually tiny flakes or spheres) to the paint. As the paint drys (Solvents flash (evaporate) off), the metallic flakes rise to the surface and form a pattern a bit like a tiled roof. The resulting finish is that slight 'sparkly' effect that you see on 'metallic' paint.
Matallics can be hard match if your doing a repair, because the perceived colour depends on how you lay down the last layer of paint with the spray gun - a horizontal pass can give a different effect from a vertical pass. Skilled paint sprayers know this and behave accordingly when doing parts which are to match up.
One good thing about metallics, is that when the tiled roof of metal pigments form, they generally tend to do a very good job of 'covering' - i.e. you can't see through the paint to the primer. The ability to see through the paint is called 'opacity' - next time you see an Imola Yellow Audit S3 - check the match between Bumper and Bonnet and try not to laugh. Yellow is notoriously opaque - the colour of the primer is critical in achieving the correct final perceived colour.
Sorry - I've spent to much of my life being involved with paint!
Here come da judge...
