Hello.
Car has been of the road now for a few months and I have been looking around the Internet for other people that have had the same problems as me. I seam pretty common problem and just wanted to know the best way around this. So here is goes
I came along when I was driving down a road near me to go to work and suddenly lost all power and just felt like it was really struggling and had no pulling power at all. Also the engine movement light had also come on.
Had a look at it for a while and didn’t have a clue.
Took it to a local garage later that week or 2, and he had a look at it, tested the coils sparkplugs and them little things Went back few days later and he said he thinks that it is the ECU. Also said only 2 cylinders were running so this had to pull the other 2 round manually.
I then came on here and other places and lots of people had the same problem as me and got new ECU for 300-600 GBP. Phoned Fiat and they said 450+VAT+fitting, also tried Fiat specialist garage and he said he knows what the problem is and that he can get second-hand ECU keys locks and key barrel for around 300+VAT.
There is a salvage yard near me with quite a lot of punto’s which is quite worrying, so I got an ECU out of there and placed this in mine, and didn’t work. Also tried phoning around to see if I can get a second-hand ECU recoded, apparently not.
So now I am thinking if I get the keys, locks and ignition barrel and fit this as well as the ECU from the same car as the keys will this work or will I have to do something else.
Please help if you can.
Thanks for your time in advance
