Does anyone have a wiring diagram to show how the peripherals are connected to the main ECU on a Mk2B Punto? For some reason, the Haynes doesn't include this info (Haynes for Mk1 Punto does include a diagram but it's a different ECU).
I need ECU pinout and wire colours for the peripherals which are:
Injectors
Throttle position sensor
RPM/TDC sensor
Lambda sensor
Coolant temp sensor
Air pressure/temperature combined sensor
Idle stepper
Ignition coils
Diagnostic socket
Evaporation solenoid
Speed sensor
Knock sensor
Camshaft position sensor
Also any info/schematic for the separate power steering ECU would be useful.
Cheers,
Red.
Injectors
RPM/TDC sensor
Lambda sensor
Coolant temp sensor
Idle stepper
Ignition coils
Diagnostic socket
Speed sensor
Knock sensor
Cheers,
Red.
