has anyone tinted the inside of their lights? just wondering coz ive done mine on the outside but its come out in a matt finish, but dunno if i spray the inside if itll look gloss, plus will the heat from the bulbs affect the spray?
the best thing to do is to mix a small amount of black paint with some laquer, give the lights a light rub down with p800 then some plastic primer(this stuff is clear) then the laquer you mixed earlier, it'll come out really shiney then.,.,,
my m8 did the inside and they luk shiny but his was on the new fiesta, so dont no if it will be the same but im sure it will, by the way the side bumper strips on the puntos if u take them off is there any holes in the door or r they stuck on with adhesive or something
cheers!! gonna try it i reckon, if it dont work then ill take it off! as to ur Q bout the side strips, yeh theyre stuck of with sticky pads, it u use a hairdryer to heat them up and then peel of the strips SLOWLY then there will be less residue to remove!!
nice 1 m8 il do that 2mra luks well better without em i jus fort they were like screwed on or sumthin, cheers nice 1, what else do you think i cud do to my car iv only got the 1 pic but if u could come up with sum ideas it wud b top, cheers
