oriongreypunto
hi
i got my car lowered in the summer , i bought the springs from fast fiat which said it lowered by 35-40mm , the back of the car is perfect , its lowered more than 40mm must be around 50mm once it was set. The front however is not low enough , the puntos are high as standard and its lowered it around 35mm but i would like the front to be around 50mm too. If i bought say the spax spring which lower 60mm can i keep the back springs in and just change the front springs ? i think the springs that i got in the front just now would lower it further its just the weight of the 1.2 8v is not pushing them down enough. So would it be a waste of time going for the 60mm if the weight is not there ?
thanks.
oriongreypunto
thanks.
oriongreypunto
