General Heating not working!!!
zoe3558
hi ppl back again!!
this time round its my heating!! before it started to become winter my heating didnt seam to be getting hot and slowly now has gone all together.
it just blows freezing air and is extreamly dangerous coz my windows steam up and i cant see!.
could it be sumthing to do with the water pump? asked my stepfarth look at it and said wen he felt the water pipes it was soft like no water was going through??
Also in the mornings when i start it, it seams to want to cut out. i let it tick over for a bit n wen i rev it it make a wistling noise lol...
if you need me info let me know..
the zo :)
Check your water level.
Try bleeding the coolant system.
Underneath your heater control knobs you have a slider, make sure this is set to the picture of the windscreen and the arrow going into the car.
As said above check your water level if low top it up with water and some coolant is the housings from the radiator warm at all after the engine has been runnin for 10mins at least they should be if not could be the thermostat has gone possbilty an air lock aswell... The noise is common had it in both my mk1 and mk2 some say its the tensioner some say its the alternater but really dosnt bother me cause its gone the time the car warms up well should be if your got it constant though get it checked out...
hi ppl
ive Checkd my water level and its fine i even got the stepfarth to bleed it and it was just air coming through. he reckons its a air lock aswell and it is set to the picture of the windscreen and the arrow going into the car. lol im not that stupid ppl...
the noise does go after the car has warmed up... so why does it do it?
thanks for your help
the zo :)
hi
Not sure if there Is any excessive steam comming from the exhaust once the engines warmed up? will look after work n there is no mayonaise.
thanks the zo
hi
thanks the zo
hi
thanks the zo
hi
no the bleeding never sorted it... just guna change the pump n hope for the best let ya know if it fixes it...
cheers for your help
the zo :)
hi ppl
my car fixed itself lol amazing just started working again
happy days:)
thank
the zo(y)
