Old 07-11-2006   #1
Overfill pipe? fuel leaking
A little help required if possible.
I have a mk1 punto75 1.2 16v.
Whilst filling the tank, when near to full, petrol will leak from the tank, this has happened a few times and is a pain in the arse, also dangerous.
The petrol attendant some it might have an over fill pipe...
Is this true? what can i do to stop this happening, as i now avoid filling the car up to the top, and just settle for 20 hear and there.
Any help will be grately appreciated
cavking is offline Reply With Quote Quote
Old 07-11-2006   #2
Re: Overfill pipe? fuel leaking
sounds like you have a leak somewhere from the tank 2 the nossle filler hole pipe? there could be a loose connection from the pipe? if you have a look under the o/s/r wheel arch you will b able 2 see the pipe? be very carefull just incase it is loose, but give a little wiggle and inspect that section of pipe beut be very watchfull it does not come loose when you are near the tank areait could spit petrol everywhere. best done on a ramp are jack up and supported b for you go under the car? its a plastic tank and filler pipe, it is possible it could be that simple. the over fill pipe is in the filler cap section if there is one? so it would have 2 be nearly over filled (I.E over fill pipe) 2 spill ou that way...
be very carefull when doing the above? just incase it is loose and you do try 2 wiggle it. watch out just incase it comes off and spits petrol everywhere.
Teddy Danson is offline Reply With Quote Quote
Old 07-11-2006   #3
i also forgot 2 mention? if it is like the 55 model? try and look at the fuel filter, it is also in the same direction, under the o/s/r arch but more under the sil. they corrode like mad and also can leak petrol thuss making u think its coming from the tank.
hand that problem 2 :-)
Old 07-11-2006   #4
Jaaaag man.
Puntoboy's Avatar
Puntoboy has donated!
Quote Originally Posted by cavking
Does it have or has it ever had 17" wheels?
its common for these to rub on the over fill pipe causing exactly what you are getting.
I had it on mine and it would only let me put 20 before leaking.
MY15 XF R-Sport Sportbrake 3.0 IRR / Black Pack / Winter / Parking / Mirror / Keyless Entry / Adaptive Dynamics / Dark Dracos / Carbon Veneer & Mirror Caps / XFRS Carbon Diffuser
Puntoboy is offline Reply With Quote Quote
Old 07-11-2006   #5
Jaaaag man.
Puntoboy's Avatar
Quote Originally Posted by Teddy Danson
He said it was a 75 matey.
Old 07-11-2006   #6
are they differant? the fuel setup would b the same? maybe i am wrong...
only suggesting for his help?
Old 08-11-2006   #7
Thanks for you advise guys, i will try and inspect it today
I will let you know the outcome
Old 08-11-2006   #8
I have taken the fuel pump plate off (under the passengers seat) and there is a black pipe running down the right hand side, this has two little small holes in it.
Around the top of the tank there is petrol residue, and the pipe is clean were the holes are..
This must be the problem.
What i can understand is how this hole have been created, there is nothing for them to rub against...
Old 08-11-2006   #9
^^^Joker
CinquePunto's Avatar
CinquePunto has donated!
It may be a brittle overfill pipe. have a look in the drivers side arch at the pipes which lead from the fuel filler to the tank - they'll be towards the front edge of the wheel arch.
Also, just for future reference, the 75 is an 8v, not 16v...
CinquePunto - Five Point Photography - Adam
CinquePunto is offline Reply With Quote Quote
Old 08-11-2006   #10
Quote Originally Posted by CinquePunto
Thanks, its my girlfriends.
Old 08-11-2006   #11
Burninator of threads!
faster4_tec's Avatar
faster4_tec has donated!
Mongolia
55/60 and 75 are mean't to have different fuel filter fittings,
like a quick release clip things and a 90degree bango fitting, but often they are muddled up and all cars have all setups.
just check your fuel filter clip things aren't leaking like crazy!!!
bango fittings are sound, up until you take them off, then they can crack.
Volvo for Life
faster4_tec is offline Reply With Quote Quote
(T) Leaking fuel pump killeruno88 Uno 3 26-09-2006 18:52
Adjusting fuel pressure regulator jug Lets Talk FIAT 0 08-08-2006 12:29
(T) 899cc Fuel Tank - AGGHHH!!! Sei-Mad Cinquecento / Seicento 19 10-10-2005 02:35
(S) Fuel Tank Leaking! funkycinq Cinquecento / Seicento 2 03-02-2005 13:56
(T) OH CRAP!!!!! FUEL LEAK!!!!!!!!!!!!!!! Damo Cinquecento / Seicento 14 15-01-2004 06:19
