Thread Tools
Old 07-10-2006   #1
Engine shaking - Fiat Punto
Hi all,
I have a 1.1 Fiat Punto. When I start the car from cold, in the first gear (until you get speed),the engine is shaking and the hole gear box. When the engine starts to warm up, this shaking is disapearig. I changed the clutch recently, because the mechanics where saying that is probabilly from this but it hasn't. I would apreciate if you could help me with this.
Thanks.
cocojumbo is offline Reply With Quote Quote
Old 07-10-2006   #2
Born to be riled
Steve-0's Avatar
Steve-0 has donated!
Re: Engine shaking - Fiat Punto
Have the checked ALL the engine mountings are in good fettle and secure?
Steve
Steve-0 is offline Reply With Quote Quote
Old 07-10-2006   #3
just can't get enough
toad101's Avatar
toad101 has donated!
wifes cinq had same prob changed gearbox mount and all is fine now
toad101 is offline Reply With Quote Quote
Old 07-10-2006   #4
I checked the mountings and everything looks fine. I will try to replace them but is wierd, it does that only when the engine is cold.
Old 07-10-2006   #5
toad101's Avatar
have you checked gearbox oil
Old 08-10-2006   #6
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
could it not be some sort of electrical prob due to all the damp weather maybe car is only firing on 3 cylinders when cold and therefore shaking, then when it warms up it comes back to life.
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline Reply With Quote Quote
Old 08-10-2006   #7
I didn't check the gear oil, but I will (anyway if there is not enough oil in it, some strage noise would've come out of the gearbox, but is not). I still think it might be an electrical problem. I also checked and replaced the spark plugs and it does the same. I will check the coil conections. I also wonder if one of the two coils is faulty. I don't know how to check them without having them replaced.
Old 08-10-2006   #8
My 1.2 punto did the same,when you started it up the engine shook like mad and then it settled when it was warm,about two days later it overheated and it was the head gasket,the shaking must have been a sign it was on its way out....
fishingpaul is offline Reply With Quote Quote
Old 08-10-2006   #9
Quote Originally Posted by fishingpaul
Yeah mine did the same thing mate
Punto 1.2 ELX 8v -
15" Deep Dish MIM 1800 Alloys, Fully smoothed except handles, punto spoiler, lowered on Rayvern Hydraulics, Plush Automotive Install
Elfy is offline Reply With Quote Quote
Old 08-10-2006   #10
Punto.Power has donated!
Maybe leads or coils just woundering when you start the car from cold does it shudder and the whole car shakes while it idles?
Punto.Power is offline Reply With Quote Quote
Old 08-10-2006   #11
I have this problem since at least 6 months and if it would've been the head gasket, it would've been blown by now (the engine starts normal at the ignition - it does that only when I'm moving). I will try to have a look to the coils and electrical connections, to see if there is the problem.
Old 08-10-2006   #12
i cant see it being an electrical connection since the car gets better as it warms up maybe a fuel related problem.. when starting it first time slightly press down on acc pedal rev it for at least over a minute then try driven..
Old 10-10-2006   #13
You might be right PUNTO POWER. After I first started the car in the morning, I pressed the acc pedal for over one minute and the car started smoothly without shaking. I want to see if tomorow is giong to be the same. In this case I think, I will have to check all the fuel circuit to see were is the problem.
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 18:15
Car & variant in your mini profile Goldie Punto Site Ideas 33 20-03-2007 13:53
(T) engine swaps HP Cinquecento / Seicento 0 31-12-2004 01:17
MODELS FIAT SHOULD MAKE! jetweed Lets Talk FIAT 61 30-08-2004 22:38
