Technical Juddering when braking at low speed
bravo1800
All,
My friend has a Punto sporting and when she brakes at low speed the wheels judder and is felt through the steering, she has been to fiats and they say its the power steering column and the abs pump is knackered can anyoen else shed light on this problem, as they have also said she should get rid of it due to these problems but they did say they were not sure if replacing these two parts would cure the problem.
Regards
bravo1800
Check Brakes, If your discs get really hot, they can some times warp/ bend slighty. this may cause the shaking.
Also if they have steelies on, check for no major dints in them.
