Last saturday i replaced my front discs with some EBC discs (just the normall ones). As youll see from the pics they where in need of changing!!
Befor :
After
In the top pic you can see that there is loads of pad left. To me they look almost new but i did notice that the top and bottom of the pad had quite a lot of wear compared to the centre of the pad. There was a taper about 15mm into the pad which was about 3-5mm deep (if that makes sense :/ ) I took the next pic today. They have probably done about 15 miles since the change, not very much i know but you can see where the pads are wearing into the disc..
Is it normall for they to be uneven wear to begin with and will the pads bed in and even out over time?
Any advice would be great.
Cheers , Adam
Befor :
After
Cheers , Adam
