Old 04-08-2006   #1
fenton_jd has donated!
MOT = Failed - Failed - Failed.
Reasons for certificate refusal:
1) Nearside headlamp not working on dipped beam
2) Nearside headlamp not working on main beam
3) Offside front (subframe) suspension component mounting - prescribed area is inadequately repaired **DANGEROUS**
4) Offside rear (front bush) sub-frame rubber bush deteriorated resulting in excessive movement
5) Offside rear road wheel distored
6) Offside front shock absorber has a serious fluid leak.
Advisory Notes:
7) Rear all direction indicators slightly discoloured.
8) Nearside rear (front bush) subframe rubber bush deteriorated but not resulting in excessive movement.
9) Rear (all) brake pipes slightly corroded.
10) Nearside front shock absorber has a light misting of oil.
11) Nearside front brake hose slightly deteriorated.
12) Offside front brake hose slightly deteriorated.
13) Surface corrosion on underside of car.
14) Surface cut in offside rear tyre wall.
Oh dear
fenton_jd is offline Reply With Quote Quote
Old 04-08-2006   #2
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: MOT = Failed - Failed - Failed.
So it needs new suspension and a steel wheel? Not a bad fail sheet. Gives you reason to fit those uprated struts and springs you've been promising yourself!
You might find the light just needs the plugs pushing on properly.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 04-08-2006   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
Did you not check the lights beforehand?
Old 04-08-2006   #4
Meh it's a 15" Fox Racing alloy wheel, was on the car when we bought it. Can't find the wheel for love nor money on the net either.
What I think happened with the headlight is that the connector wasn't on properly, which caused it to spark and get extremely hot which pretty much melted the connector away and the **** which has been left on the contacts means the bulb doesnt work properly. If you tweak the wire it'll work. Just obviously didnt work for the m.o.t bloke.
Have a set of Bilstein OE spec shocks sitting in the hall ready to be installed anyway.
Will there be some sort of product number engraved on my alloys or something? Don't know too much about this sorta stuff. I dont want to have to shell out for a replacement of the entire set of wheels.
Help appreciated
Old 07-08-2006   #5
Question 7 Spoke alloy wanted
For 2000 (W) Brava SX80 - despite dealer saying the SX80 never had alloys, mine did, but one has hairline fracture so looses air - if I use a liquid puncture seal does anybody know if the crack is liable to progress and become dangerous?
Therefore I wants a 6J x 15in 7 spoke Fiat wheel, the spokes have a shape like rowing oar blades, anybody got one in the back of the garage?
Cheers, Pip..
4cylinder is offline Reply With Quote Quote
Old 07-08-2006   #6
x Alex x has donated!
Quote Originally Posted by T14086
yeh it pays to check the obvious fail points first to save time!
Grande Punto 1.9 Multijet Sporting
x Alex x is offline Reply With Quote Quote
(G) Failed MOT, failed suspension strut Scorg Bravo / Brava 10 04-08-2006 09:13
(G) My First MOT and I Failed arthur231283 Cinquecento / Seicento 2 04-07-2006 19:36
(T) Failed MOT pranksta Cinquecento / Seicento 7 18-05-2006 11:03
(G) Seicento failed mot GhostWKD Cinquecento / Seicento 7 11-01-2006 23:43
(T) MOT Retest Results........FAILED! mdsremos Cinquecento / Seicento 15 25-06-2004 22:10
