![]() | #1 | ||
Posts: 24 Thanks: 0 Trader Rating: 0 | Broken key!
![]() | #2 |
Posts: 4,756 Thanks: 18 Trader Rating: 0 ![]() | Re: Broken key! they may be able to repair the key but only the dealer can supply a new coded key
__________________ Grande Punto 1.9 Multijet Sporting |
![]() | #3 | ||
Posts: 24 Thanks: 0 Trader Rating: 0 | Re: Broken key! ok, so its only the dealership that can supply me a new key? Bet then that its gonna cost me a arm an a leg! Anyone no how much?
![]() | #4 |
Posts: 29,985 Thanks: 1068 Trader Rating: 0 ![]() | Re: Broken key! £38 |
![]() | #5 | ||
Posts: 788 Thanks: 48 Trader Rating: 0 ![]() | Re: Broken key! Cheaper option may be to take bits to one of the after market guys or locksmith with the right equipment. Keys about £20 each + code from fiat £20 + £40 key coding and reset. You must be looking at £100. Not too bad considering you have lost all of the cars security. Tony.
![]() | #6 |
Posts: 29,985 Thanks: 1068 Trader Rating: 0 ![]() | Re: Broken key! key £38...codecard(if you dont have it) £5.00...programming(half hour)£25 = £68. Remember its a code 2 system also there are alot of crap keys being sold by locksmiths/shoe & key cutting shops,they simply buy cheap keys which can give problems. As for costing a 'arm & a leg' a 2002 punto would of cost you a few quid in the first place so £60-100 is nothing really. |
![]() | #7 |
Posts: 83,522 Thanks: 1480 Trader Rating: 10 ![]() | Re: Broken key! as a temp solution, you can take the 2 broken bits to a key cutters, get a no code key cut with them, then tape your plastic bit off broken key to the new key, should work, but only temp, get new key(s) from fiat, you will need them anyway when it comes to time to sell the car
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #8 | ||
Posts: 24 Thanks: 0 Trader Rating: 0 | Re: Broken key! [QUOTE=T14086]key £38...codecard(if you dont have it) £5.00...programming(half hour)£25 = £68. Remember its a code 2 system Fiats want £150 +vat! What is the code card? At the mo I have got a key cut at a locksmiths and have taped the broken key to it, but this is a temp measure. Can I get the code for my key(car) from Fiat? Whats a code two system? I no what your all thinking but I am not familiar with fiats as this is my first one... cheers!
![]() | #9 | ||
Posts: 46 Thanks: 0 Trader Rating: 0 | Re: Broken key! What about if its just a basic blue key thats been lost? This is what has happened to me (fiat punto M reg 55sx 5 door) and im absolutely gutted - only had the car for 1 hour ![]() If I go to a fiat dealership will they sort me out for £38? All advice gratefully appreciated - cheers Also can I just buy a key set and locks from a scrapyard instead? How would I prove what key I need? Is it the engravings on the key barrel?
![]() | #10 | ||
***** Friendly | Re: Broken key! no, thats got a different system (code 2 rather than yours with is Code 1) also, he has a key ![]()
![]() | chloe1705 | Bravo / Brava | 14 | 25-08-2008 15:26 |
![]() | foster | Bravo / Brava | 6 | 30-05-2006 23:55 |
![]() | tony witney | Bravo / Brava | 4 | 04-03-2006 23:14 |
![]() | tony witney | Bravo / Brava | 4 | 24-10-2005 23:12 |
![]() | tony witney | Bravo / Brava | 14 | 20-10-2005 21:36 |
