Blondeinapunto
- Jun 28, 2005
- 18
- 5
Help someone!, Mk1 P reg has failed MOT as the back lights dim slightly every time the indicators flash. Bad earth i am told, so i have cleaned the connectors to the lights, cleaned the bulb holders, cleaned the earth contacts in the rear boot, cleaned the earth contact under the battery and cleaned the battery earth. Still no better. Taken all the indicator bulbs out to see if any corrosion under them but no. Anyone out there with experience of this sort of problem? otherwise its going to be an expensive trip to the auto electricians..... Only thing not pulled out yet is the indicator relay.
