im Axle Specialists
Thread Tools
Old 03-02-2004   #1
Gearbox Bearings?
My wife's 97 elx 16v suffers from judder occasionally when pulling away, with some gearstick wobble.
I have been advised that it could be the gearbox bearings.
Can anybody advise on this and how much to correct.
gazza007 is offline Reply With Quote Quote
Old 04-02-2004   #2
I had that porblem but now it has stoped but the gear stick never wobbled... thats probably the cause of my new problem that my car wont go into reverse gear now so da 6th gear bearing has gone.
Punto 1.6 Turbo
Coshstar is offline Reply With Quote Quote
Old 05-02-2004   #3
Hi Gazza
This is more likly to be caused by a faulty clutch.
No way gearbox bearings
If you have had a clutch before was it a recon item because they are bad for clutch judder.
david75 is offline Reply With Quote Quote
Old 05-02-2004   #4
gearbox bearings is given away by the noise disappearing when you push the clutch down. It's a rattle and doesn't cause judder. David's suggestion is the most likely one.
Spirito di Punto | M-reg 55SX, black, 5dr. Clear repeaters. Remote locking fitted, no light confirmation yet though - need relay fitted
pritch is offline Reply With Quote Quote
Old 05-02-2004   #5
Cheers Guy's,
Car goes OK and doesn't really cause too much of a problem so will have it looked when serviced.
Quite a nippy motor though.
Old 05-02-2004   #6
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
i would check your gearbox/engine mountings as these will through out a judder and vibration through the stick
Custard boy the man who loves the man from Creative
Thread Tools
(T) gearbox update 3 - some advice please! StreetRacer Punto (Mk2/2b) 4 18-10-2007 21:03
(T) gearbox help marky23 Punto (Mk2/2b) 5 02-06-2004 01:31
(T) gearbox update....please help StreetRacer Punto (Mk2/2b) 7 31-05-2004 01:50
(G) 1986 March 965cc Panda 4x4 gearbox et al waddow Panda (Classic) 2 10-12-2003 03:21
(G) Panda Gearbox steveyensen Panda (Classic) 62 09-07-2003 17:21
