FIAT Auto Specialist Team
Thread Tools
Old 29-06-2006   #1
Project ideas
Ive recently been to the scrappy for the first time ever and well i was amazed... the amount of upgrades possible got my idea factory workin
three questions..
1) How difficult is it to install PAS off an ELX into a 55S?
2) How difficult is it to fit elec windows from ELX into 55S?
3) Central lockin from ELX to 55S
I found an ELX but the insides had been fire damaged ruined the centre console and the lot but just askin incase i see another
B3NN3TT is offline Reply With Quote Quote
Old 30-06-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Project ideas
i go to the scrapyards almost every week, its criminal how many great bits are just sitting there in the mud rusting away. but ti means bargains for anyone who can be bothered to go and get them.
i've done the pas conversion on an old rover 200, it only required the pump to be fitted along with its hoses and the steering column with the rotarty valve on. just 2 hoses to connect them together. to power the pump you need to get a belt and make sure your engine has the required pulley to drive the pump. usually the pump will be driven by a pulley which is present on all models and the only difference is the belt, however some models have an additional pulley only on pas models so check out how the pump is driven on a punto with pas.
electric windows is very easy. you dont need to worry about wiring it in the same way fiat did. you will need the elec window motors, the switches and thats it if you're willing to wire things up in your own way. if you source an ignition live and earth to each switch and then wire each switch to its elec window motor it will work. i suggest you fuse the live to eahc switch. also to get the switches illuminated they will have another pair of wires, just connect in parrallel to the illumination wires on another switch. its easy.
central locking can be more of a pain to get right if removing from a donor car. its often easier to buy a universal kit with a pair of actuators to fit in the doors. then you will have remote central locking as most diy kits come with remotes. i se them on ebay for cheap all the time. (less than 20)
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 30-06-2006   #3
Re: Project ideas
Thanks for the reply ill check out the central lockin on ebay as we have an account hoping to get back to the scrappies soon
Old 30-06-2006   #4
Riding 7cm of the deck
raptor's Avatar
raptor has donated!
Re: Project ideas
i think some people have to change the glass when fitting the winding regulators etc to 55's and 60's
i got the microscan central locking kit, was a piece of p**s to fit and works fine (been on the car for over 1 1/2 years)
http://www.fiatforum.com/signaturepics/sigpic7407_1.gif
raptor is offline Reply With Quote Quote
Thread Tools
(G) Tempra 1.4 RPE Project ROMKA Tempra 0 22-06-2006 16:54
Alevel final project robcento Leisure Lounge 1 28-06-2005 16:29
Another project question gaz.d Leisure Lounge 33 19-10-2004 21:19
ma project Ic3 Lets Talk FIAT 47 15-07-2004 02:40
Spread the word ideas? ben Lets Talk FIAT 47 10-01-2004 18:17
