R rossco New member Joined Jun 29, 2006 Messages 2 Points 1 Jun 29, 2006 #1 can you help about 10 days ago my exhurst started blowing and now oil is leaking from near the sound of the blowing. Any idears? FIAT (Fix It Again Tomorrow)
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh Jun 29, 2006 #2 well theres really little i can tell you. go underneath and try to see where its leaking oil and where its blowing. oilcould be from many areas.check the obvious like the filter is tight also the sumplug
T Thompatruck New member Joined Jun 29, 2004 Messages 27 Points 9 Location Newcastle Jun 29, 2006 #3 If your exhaust is blowing are you sure it's not just a water and carbon mix that'll come out of the exhaust? (I know it's a long shot but maybe ) Alternately if you've hit something (like a speedbump) you may have smashed your exhaust and hit the sump at the same time....but I hope not Last edited: Jun 29, 2006
OP OP R rossco New member Joined Jun 29, 2006 Messages 2 Points 1 Jun 30, 2006 #4 i take it a broken sump and new exhurst is going to be costly? I cant recall hiting anything recently or even ever in my punto! Badger in my Citroen AX caused some damage mind! If sump is bost, what is the rought cost of new one?
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh Jun 30, 2006 #5 your getting ahead of yourself.you havent even looked yet i assume
