Old 31-05-2006   #1
Guadeloupe
Problem with my mcrich performance chip.
hi this morning I wanted to change my chip of origin by a mcrich performance chip. My chip of origin is welded, therefore I unsoldered it then I welded a support of chip then I pose my new chip . I replug all the car does not start, I puts my old chip and it does not start . What can i do? did my ecu die?
The indicator of the key code does not ignite with starting.
I specify that my model is: FIAT punto mk1 1l2 spi 8v 60 1997
thanks for replying
timeless is offline Reply With Quote Quote
Old 31-05-2006   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Problem with my mcrich performance chip.
Quote Originally Posted by timeless
thanks for replying
TBH i would suspect oyu have damaged the ECU motherboard on the desoldering.its very easy to overheat a motherboard desoldering or even lift a trace if your not careful
Old 31-05-2006   #3
Trader Rating: 16
beau has donated!
buy another, there normally 99p-5 pounds on ebay
Maserati 3200 GT Coupe
beau is offline Reply With Quote Quote
Old 31-05-2006   #4
Trader Rating: 16
beau has donated!
Old 31-05-2006   #5
custard's Avatar
Trader Rating: 1
yes but not posted to Guadeloupe
Old 31-05-2006   #6
Trader Rating: 16
beau has donated!
Quote Originally Posted by custard boy
email ebayer, 9 times out of 10 there post to another country in europe.
Old 01-06-2006   #7
Guadeloupe
ok so my ecu is died
Old 01-06-2006   #8
Trader Rating: 2
col7104 has donated!
Gaudeloupe is in Europe
col7104 is offline Reply With Quote Quote
Old 01-06-2006   #9
custard's Avatar
Trader Rating: 1
Quote Originally Posted by col7104
i was referring more to costs than areas.easier to source locally.
to the original post closely inspect the motherboard around where you soldered/desoldered. look for broken traces and if oyu have a multimeter try and check continuity from the chip pins and trace to a termination point.
Old 01-06-2006   #10
Guadeloupe
Can i buy a 1L1 ecu for my 1l2?
Old 01-06-2006   #11
Trader Rating: 2
Sorry I meant in regards to Beau's post, last time I checked Gaudeloupe wasn't in Europe ....I'll get my coat
Edit for Timeless:
The safest bet is to find an ECU from a scrapyard with an exact matching serial number. This is written on the ECU label.
Old 01-06-2006   #12
custard's Avatar
Trader Rating: 1
1.1 will be fine
Old 01-06-2006   #13
Guadeloupe
I checked continuity in all board = no problem.
Can i have a big picture of the board in order to expect the network?
Old 01-06-2006   #14
Guadeloupe
if i buy a new ecu, i must buy it with his red key?
Old 01-06-2006   #15
Trader Rating: 16
beau has donated!
not if your fitting the chip...
(T) Cinq Sporting Performance Chip mckcrich Cinquecento / Seicento 300 01-05-2020 04:41
(T) Punto (second version) Dualdrive problem andre79ge Punto (Mk2/2b) 2 10-02-2005 22:43
(G) Cinq Performance Chip Mr Brown Cinquecento / Seicento 4 25-08-2004 20:01
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
(G) Performance Chip Development mckcrich Cinquecento / Seicento 13 27-04-2004 05:15
