I don't expect anyone will know this but i'm pretty stuck tbh,
Basically i recently bent the rear beam on my hgt after one of my rear tyres blew out. So i got a new rear beam from a scrap yard and as you can imagine everything was still attached to the rear beam as they never unbolt anything especially if they can just cut it off. So I stripped it down and because they had cut the ends off the abs sensors i had to smash them out as they where corroded in, i've then changed the rear beams over, everything was fine untill i took it out for a run when the tcs went ape s*it, so i turned off the tcs and carried on and the abs light came on. Today both lights are staying on permanently even after disconnecting the battery so i guess it has logged a fault code which the main dealer will have to reset, not a problem but to be on the safe side i thought i'd check the rear abs sensors to see if they were dirty etc. When i looked at them they where both about 4-5cms away from the ring on the hub and my punto manual says the tolerance is 0.1-0.7mm gap? So what i need to know is are the rear abs sensors different lenghts on diffrent years of hgt? Of course if i go into a fiat dealer and ask they won't know and will ask for my chassis number which will just show up the sensors i've already got.:bang:
