FIAT Auto Specialist Team
Old 10-05-2006   #1
Power steering
Hi Guys
Need some advice. Driving a 2000 X Punto 1.2 with 40k on the clock.
The power steering has all of a sudden got a little tempremental! It works for a few minutes or a few days and then stops workign altogether!
My local garage tells me that this is a common problem and I need to change the whole power steering unit. The unit will cost in the region of £465!
I have been offered a "reconditioned" unit through Fiat for £265 with a 1 year warranty.
My questions are...
1. Is the unit kaput and does it need changing?
2. SHould I buy a new unit or the reconditioned one?
3. Will the reconditioned unit give up after a few years??
All advice much appreciated.
beekes is offline Reply With Quote Quote
Old 10-05-2006   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Power steering
Recon unit is fine....................but it might not be the whole column that is faulty,I would get the codes read as might be just the seering ECU that is faulty or connector etc
Old 11-05-2006   #3
Re: Power steering
Hi and thanks for the reply
Would the local Fiat Dealership charge to "read the codes" and confirm exactly whats wrong? If so, what sort of money would they take?
Old 11-05-2006   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Power steering
Depends on the garage rates & wether garage charges per hour or per part hour.Phone & ask but it shouldnt be more than £30-40.
Ask for a examiner printout to confirm exact fault...to be honest at £265 thats a good deal as a steering ECU will cost about that.
Good luck & let us know how you get on
Old 23-07-2006   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Power steering
(T) power steering problem saviogimmi Punto (Mk2/2b) 12 29-11-2010 20:23
(T) Power steering Insane Stilo 1 21-03-2005 11:49
(T) Power steering aaaaaaaargh and cold/damp screech! Stevatron Cinquecento / Seicento 5 10-01-2005 19:40
(T) Power steering fluid FamilyGuy Marea 2 25-10-2004 12:33
(T) Seicento Power Steering? dawozere Cinquecento / Seicento 7 27-02-2004 15:30
