magikbilly
how to changed head gasket whats needed and how long will it take and how to tell if the heads need skimming. once the rocker cover is removed can you just remove the manifolds then lift the whole block with all the valves in how do you un bolt the block and how do you retighten with all that 90 degree thing and a orber thingy what is it all lots of help please coolant is leaking from my engine is this head gasket cos it looks like it
