Hi to everybody,
I have a punto 1.2 8v 2002, last week I had a failure of the ECU that caused the car to run on 2 cylinders. I drove it home slowly (about 10 km) and found that coils, wires, and plugs were all in order. The ECU light was solid on.
I did buy a brand new ECU which had exactly the same part number etc..I did also change the two coils, plugs and wires. just in case the failure on the ECU was due to some malfunctioning of any of these.
After installation of all this new equipment, the car started perfectly and now runs as required. The only thing is that the ECU light is now flashing. Some friend told me that the ECU needs to readapt and re-learn and hence I had to bring it to 6k revs a few times. So I did but the light is still flashing.
Some my questions:
-Is there anything else that needs to e done on a new ECU to stop this light to flash?
-could I have burned the catalytic converter in the few km i drove the car when it was running on two cylinders? I have doubts about this as the car runs very well and the light starts flashing right away after the car being turned on. I would argue that the ECU cannot figure out a faulty cat if not warm.
-any other ideas on what to check?
Many thanks for any help, I am reluctant to bring the car to the dealer as they tend to rip me off each time.
regards
Some my questions:
regards
