Technical MOT emissions failure.
johnw
Member
My 1997 55sx has failed the MOT on both 1st and 2cnd fast idle test.
CO% are 0.00 and 0.02
HC ppm are 8 and 10
Lambda is 1.05 on both tests.
The garage fitted a new lambda sensor with no change. From the readings I assume the cat is ok.
Any ideas what to do next?
hi, stick tank of optimax in, bottle of fuel injector cleaner, bottle of cat cleaner and then go and thrash the **** out of it, i mean like revving it right upto 5.5k and flooring it, down your private lands's motor way upto 80-90 :) :)
should do it :)
well thats cheap way lol
Have put some cleaner stuff in the tank and taken it for a run.
It certainly runs smoother and starts better.
Also compared my car with another one and the heater on mine blows much cooler air. Removed thermostat and its stuck partly open so have got a replacement which I will fit over the weekend.
New test on Monday.
Just says oil temp was 80C, don't know if that is normal or not.
