Old 13-04-2006   #1
Question Please help high emissions on my beloved Punto
Took my fiat punto to the MOT garage and it failed with high emissions. The MOT garage have tried to sort it but have failed. Anybody got an idea what might be the problem ?
They have tried all these:
Emissions test
1st fast idle in range 2500 - 3000 where my car was tested at 2526 rpm
Allowed: My Car
Co limits 0.30% 9.99%
Hc 200ppm 515ppm
lambda 0.97 - 1.03 0.707
2nd fast idle in range 2500 - 3000 where my car was tested at 2703 rpm
Allowed: My Car
Hc 200ppm 505ppm
lambda 0.97 - 1.03 0.696
normal tickover in range 450 - 1500 where my car was tested at 873 rpm
Allowed: My Car
Co limits 0.50% 7.11%
Hc 200ppm 505ppm
diagnostics test on electrics
block pressure test - (it's had a recent head gasket change along with the cambelt).
carbereta change
Timing check - was out about 3 degrees out ( MOT people didn't seem to bothered ).
cat checked
exaust checked
you name it, it's been checked and has passed all above except emissions.
However, I have been told today that using a meter the "Data" was OK
The car runs perfectly after an initial mis-fire.
Both myself and the MOT garage are at a loss of how to fix.
Any help would be very appreciated.
dastardly is offline Reply With Quote Quote
Old 13-04-2006   #2
Winning
GhostWKD's Avatar
GhostWKD has donated!
Re: Please help high emissions on my beloved Punto
if the timing is out it wont be igniting at the peak point putting a few unburnt drops down the system? mine ran like a pile of pooh when it was just a tooth out
GhostWKD is offline Reply With Quote Quote
Old 14-04-2006   #3
Trader Rating: 10
dave has donated!
do you mainly do short and/or slow journeys? if so a good thrashing may help,
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 14-04-2006   #4
Banned
Oldschool has donated!
I looks like it is hopelessly overfueling.
Check plugs, leads, coils, make sure the injection unit is fine (even when replaced) and lambda sensor.
Oldschool is offline Reply With Quote Quote
Old 14-04-2006   #5
Mr Pedantic
hmallett's Avatar
Trader Rating: 1
hmallett has donated!
I'd try changing the lambda probe. It's fairly cheap to do, and it certainly won't make things any worse!
Just wondering if the coolant temp sensor might be at fault. If it still thinks the car is on the cold cycle it'll run richer.
H
Quote Originally Posted by 306maxi View Post
I love the Panda forum.... you guys are so much more chilled out than the 500 guys
hmallett is offline Reply With Quote Quote
Old 14-04-2006   #6
Trader Rating: 10
dave has donated!
hasnt got an ebay 20+bhp mod has it?
Old 15-04-2006   #7
Thanks but the MOT garage have now told me that they corrected the timing.
Old 15-04-2006   #8
The garage have done more checks now
Checked plugs and leads and have also checked the injection unit and replaced the lambda sensor.
You mention coils
The only coil I know is the ignition coil, are there more than one then ?
Thanks Oldschool
Old 15-04-2006   #9
Where about on the engine is the coolant temp sensor, will ask the gararge if they tried this sensor ?
Thanks hmallet
Old 20-04-2006   #10
Took the car to a Diagnostics garage today and they have now fixed it.
There was air leaking into the Manifold that was tricking the lambda sensor
Anyway thanks for all your replies
(T) Fiat Punto ECU Wiring Diagrams arseofbox Punto (Mk1) 10 23-12-2009 15:28
(G) Buying a Punto from auction! SpunkyM Punto (Mk2/2b) 11 21-12-2007 21:19
(T) Punto brake upgrade, and a question.... keri-WMS Punto (Mk2/2b) 2 21-11-2005 21:19
(T) Punto 75 sx, high CO, subframe bushes, shocks fixitquick3 Punto (Mk1) 2 11-10-2004 14:08
