im Axle Specialists
Old 30-03-2006   #1
Riding 7cm of the deck
raptor's Avatar
raptor has donated!
Lightbulb internal lighting
was a little bored today so decided to have a tinker, i've decided to wire my footwell LED neons into the interior light circuit, that way when i open my doors my footwells light up, however i can still turn them manully using the courtesy switch am as chuffed as punch with my simple but good looking mod! its dead easy to do so if anyone wants any advice just ask!
http://www.fiatforum.com/signaturepics/sigpic7407_1.gif
raptor is offline Reply With Quote Quote
Old 30-03-2006   #2
Re: internal lighting
Thatís cool!! I did mine similar, but I wired them to the number plate light fuse, so when that light comes on the neonís come on.....its pretty cool, as I don't use em much in the day so they come on at night when the lights come on!! By the way how easy is it to change the inside courtesy light from a normal white light to a blue neon?
Duxy
Duxy is offline Reply With Quote Quote
Old 02-04-2006   #3
raptor's Avatar
raptor has donated!
dead smiple duxy, just get an LED replacement mines from varad and looks awesome, don't buy the coloured bulbs they look rubbish and weak and wear out. you can get the led ones from the 'kroozin' motorworld (?!?) stores 2 for a tenner and they are just as good
Old 02-04-2006   #4
Hey, im planning to put lights in my footwells and was stressing about where to wire them to as my punto is mk4 and couldnt find grommit into engine bay. Never thought to wire them into number plate light. How easy was it to do?
Flick
flick is offline Reply With Quote Quote
Old 02-04-2006   #5
raptor's Avatar
raptor has donated!
if you have a haynes manual just goto the relevant section for the lighting circuits and find the appropiate wires to wire into, i'll mean cutting, soldering and heatshrinking - don't know how this will affect warranty and things foryou though
Old 02-04-2006   #6
Its simple..........all you do is find the fuse for the number plate light (the one in mine was a 7.5 fuse). There will be two wires from the neon, (one is normally 2 colours, e.g red & black, and ones normally just one colour, e.g red) wrap the one with 2 colour around one leg's of the fuse, and plug it back in. Then put the other wire to an earth source (I put mine on the igintion coil), and your laughing!!!! Any problems let me know, and I ll post some pictures up!!
Duxy
Old 02-04-2006   #7
raptor's Avatar
raptor has donated!
duxy, have you made sure there is still the glass fuse 1or 2 amp still inline with the neon, its likely that the 7.5A fuse won't blow if there is a problem with the neons - the fuse is there to protect the wire not the appliance rememeber!
use V=IR and P=VI to make sure that you don't exceed the fuses rating - CC neons draw more current than the LED's so keep check of that too.
Old 02-04-2006   #8
Thanx, i will give it a go and see how i get on.
flick
Old 03-04-2006   #9
raptor's Avatar
raptor has donated!
i really don't recommend duxy's method of wiring flick so be careful!
My new ice install (& blue lighting) Ben B I.C.E 0 29-07-2005 23:17
(G) interior lighting problem with 96 ulysse davycha Ulysse 7 16-05-2005 18:14
(S) were can i buy the rear lighting circle covers cinqseeley Cinquecento / Seicento 1 19-04-2005 19:36
(T) Punto mk2 internal Fuse box?? where is it? slicks Punto (Mk2/2b) 4 06-11-2004 15:45
