Old 01-01-2004   #1
How do you change the Headlight bulb
How do you change the passenger side headlight bulb on a Fiat Punto W reg? Easily? I need help & I don't have a manual.
Jules 570_0
J Greatbatch
Jules 570_0 is offline Reply With Quote Quote
Old 02-01-2004   #2
if you're unsure, just go to a local garage or motor factors. they'll fit it for you if you ask nicely
99 Brava 100 HSX with not enough mods
mad_colm is offline Reply With Quote Quote
Old 14-12-2008   #3
Re: How do you change the Headlight bulb
I have just change the headlight bulb and I know how awkwardly placed the
casing is. I tried the conventional method but there is not enough room to get the casing out to expose the bulb and wiring.. Any how I decided to remove the bolts (3 of them) that hold the whole light unit in place and move it forward so I could get in from the back .It worked, I was able to remove the casing. There is then the issue of the bulb holding clip. This has to be removed to slide the actual bulb out. Be careful with the clip do not loose it. Put the new bulb in and put the clip back on. Its a bit tricky but try to remember how it came off. Put the casing back on then fgasten the whole light unit back. It took approx 15mins to do. Hope this helps.
listman22 is offline Reply With Quote Quote
Old 14-12-2008   #4
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Would you be able to write that up as a guide for other members having the same problem? Would be a big help
https://www.fiatforum.com/guides
Helz is offline Reply With Quote Quote
Old 21-12-2008   #5
Smile Re: How do you change the Headlight bulb
Just did this today, fantastic tip. Gonna write up a guide now if there isn't one already.
OK here we go. Fairly simple stuff but it was enough to fox us for a few hours.
https://www.fiatforum.com/punto-guid...ly-2003-a.html
BrizHatchings is offline Reply With Quote Quote
(G) Headlight bulb....!!!!!!!!!! Cr@zy Punto (Mk2/2b) 4 21-12-2008 18:37
(T) Headlight Bulb Change - Panda 4x4 TTR Panda 1 10-11-2008 16:15
(G) Headlight Bulb Change - thanks Fiat Forum DonSalvati Stilo 4 03-03-2008 19:46
(T) Headlight bulb denk Tipo (Classic) 2 16-07-2007 15:54
