General How do you change the Headlight bulb
if you're unsure, just go to a local garage or motor factors. they'll fit it for you if you ask nicely
99 Brava 100 HSX with not enough mods
I have just change the headlight bulb and I know how awkwardly placed the
casing is. I tried the conventional method but there is not enough room to get the casing out to expose the bulb and wiring.. Any how I decided to remove the bolts (3 of them) that hold the whole light unit in place and move it forward so I could get in from the back .It worked, I was able to remove the casing. There is then the issue of the bulb holding clip. This has to be removed to slide the actual bulb out. Be careful with the clip do not loose it. Put the new bulb in and put the clip back on. Its a bit tricky but try to remember how it came off. Put the casing back on then fgasten the whole light unit back. It took approx 15mins to do. Hope this helps.
