Technical Lack of power
tinnion87
My car seems to be lacking power and the engine juddering on acceleration.
It seems to me like its underfuelling. Any ideas what may cause this?
Injector light displays when cold, and restricts engine revs at about 3.5k. When warmed up its ok, and only comes on very occasionally
It has an enlarged TB fitted, and a cat-back supersprint (on a 55)
Well had a new downpipe fitted today, so lambda came out
Cheers I will try and get it on a diag. machine
Any other ideas?
Ok.
Changed TB back to original, so to me that counts out any associated problems
Also changed the lambda today, but still running rough
Can anyone suggest anything else?
richcinq said:
Sounds like the coolant temp sensor on the inlet manifold. Try putting a new one in, they are cheap and go wrong all the time.
Where can I get one?
DanGil said:
It sounds like your ecu goes into 'limp home mode'.
How do I get it 'out' of this mode
Long shot I know, but when I changed to a larger TB on my Cinque it went rough (turned out to be an extra hole i hadnt accounted for) but for some reason when I changed back it was still rough for about 100 miles, then went back to normal.
If that doesnt happen then what people have said about the sensors is dead on
Hi, I have a similar problem . Look under the bonnet at night and see if the leads or more likely a coil shorting . The spark can be very subltle and only visible at night.You may hear a clicking noise too.(y)
