Old 06-03-2006   #1
Engine Management Light/Temp Warning Light Fault
Hello everyone,
I have been having a problem with my Punto MK2 8v where I am getting erratic error warning lights coming up on my dashboard.
Every time I use my car either the engine managment warning light or temprature warning light (sometimes both) come on. It happens completely randomly either when I start the car up or when I am driving. It/they go off after a while but often come back on at regular intervals depending on the length of the journey.
When I first took the car in, my local dealer said it was a faulty temprature gauge and would order one in. Recently though, the car started misfiring as I was leaving work and I thought it would break down. Thankfully after turning the engine off and back on it seemed to run ok but with both warning lights on.
My question is, I had the ECU replaced about six months ago and I don't think the garage is telling me the whole truth about this temperature gauge and I think it might be linked to the ECU.
Has anyone experienced this or got any ideas? I don't want to get skanked again after shelling out £300 for a new ECU only quite recently.
bugalugz is offline Reply With Quote Quote
Old 09-01-2009   #2
snotta
snotta has donated!
Re: Engine Management Light/Temp Warning Light Fault
Quote Originally Posted by bugalugz View Post
Hello everyone,
i have a brava 51 plate, my ems light came on, took it for a diagnostic report for 30.00, it said 3 cyclinder was missing, need to replace coil at cost of 130.00. so i went and bought a coil for 50, hAD IT FITTED FREE! guess what still the same, so after coming on this site, i have been advised it could be the plug or ht leads, so suggest you try the plugs first, then the ht leads, mind you i have priced the leads and they are 28, hope this helps, but you may need to take it, and have a report, as they are all codes for different problems
snotta is offline Reply With Quote Quote
(T) engine management light flashes ? jonny2005 Punto (Mk2/2b) 16 21-05-2011 15:04
(T) Dash Warning Light thomash Punto (Mk2/2b) 9 18-01-2007 19:58
Rolling roads figures, fact or fiction? J333EVO Lets Talk FIAT 18 01-11-2005 15:36
(T) Sei - Engine warning Light PickeringDM Cinquecento / Seicento 1 14-06-2005 00:13
(T) Engine management light... (amber) davetrouser Punto (Mk2/2b) 1 09-07-2003 22:02
