D David M New member Joined Sep 18, 2005 Messages 20 Points 6 Mar 3, 2006 #1 I have an 8v, 1200, year is 2000. When I start up there is a sound of like water gurgling through the system. Any ideas what it is? Could the system require bleeding? The noise disappears when car is warm.
OP OP D David M New member Joined Sep 18, 2005 Messages 20 Points 6 Mar 3, 2006 #3 How do you bleed it?
OP OP D David M New member Joined Sep 18, 2005 Messages 20 Points 6 Mar 4, 2006 #4 Could the head gasket be gone? The car runs rough for a few minutes when cold also.
D DanGil Member Joined Jan 23, 2006 Messages 875 Points 136 Mar 4, 2006 #5 Theres two bleeding points, one on the top right hand side of the rad and one on a pipe going to the heater matrix.
OP OP D David M New member Joined Sep 18, 2005 Messages 20 Points 6 Mar 6, 2006 #6 It is the head gasket! This is my second Punto and the gasket went in the last one as well. This time it has gone at 40000m. Such is life. Last edited: Mar 6, 2006
LanciaMad Established member Joined May 13, 2005 Messages 1,176 Points 363 Location Toon Mar 6, 2006 #7 You may find that the head gasket went as a result of the water system needing to be bled.....
