FIAT Auto Specialist Team
Old 12-01-2006   #1
wind screen washer bottle
he hello peeps think i might need a new wind screen washer bottle as i filled it up the other day. and the next day was empty when i came to spray window .filled again noticed water dripping down .could of craked in the cold ??? if so are all the washer bottles the same on the mk1 ?? if so is it just a case of taking down the passenger inner wheel arch cover down ? rang a fiat breaker he said a tenner
tccat11 is offline Reply With Quote Quote
Old 12-01-2006   #2
Jaaaag man.
Puntoboy's Avatar
Puntoboy has donated!
Re: wind screen washer bottle
all non GT's were the same.
wheel off, inner arch out.
then its 1 13mm nut on the wing, and 1 10mm bolt under the bottle.
MY15 XF R-Sport Sportbrake 3.0 IRR / Black Pack / Winter / Parking / Mirror / Keyless Entry / Adaptive Dynamics / Dark Dracos / Carbon Veneer & Mirror Caps / XFRS Carbon Diffuser
Puntoboy is offline Reply With Quote Quote
Old 12-01-2006   #3
think its different on the diesels
1998 PHASE 2 PEUGEOT 306 IN BLAZE YELLOW
marky23 is offline Reply With Quote Quote
Old 12-01-2006   #4
many thx peeps
Old 12-01-2006   #5
Burninator of threads!
faster4_tec's Avatar
faster4_tec has donated!
Mongolia
whar about the largerr gt and diesels, can i fit one of them too my non gt model, as the std on it like 2.5litres and needs refiliing every few days, or even several times a day if I am dirving any distance (i.e 750mile roundtrip to loundon).
the gt bottle is 7litre or something, will it fit?
Volvo for Life
faster4_tec is offline Reply With Quote Quote
Old 12-01-2006   #6
Jaaaag man.
Puntoboy's Avatar
yes it will. and you need to do it block the pipe for the headlight washers and use the extended connection that the GT wiring loom has to reach the pump.
AFAIK the deisel one is no bigger than the standard one.
the reason the GT one is bigger is due to the headlight washers.
Old 12-01-2006   #7
Mongolia
cool, i will look for one of them then.
here at uni we have loads of the automotive wiring loom water proof type connectors and wiring kits (huge boxs of seals and clips etc) so does the motor work on one of them (you know two prong, yellow black and red bits?, like the ecu diaganostic plug behind ecu?)
Volvo for Life
Old 12-01-2006   #8
Jaaaag man.
Puntoboy's Avatar
its the same connector as your current pump, needs extending as the pump it on the far side of the bottle on a GT.
(T) WIndscreen washer bottle? Slippy Cinquecento / Seicento 4 19-11-2005 00:33
(T) Uno 45 fire washer bottle Timm Uno 15 26-09-2005 10:21
(T) Washer Bottle Leak - AGAIN. lanciaevo1 Cinquecento / Seicento 1 23-07-2005 22:46
(T) Water Leak From underneath the Washer bottle rick_p Cinquecento / Seicento 7 13-03-2005 23:39
(T) Window and Headlamp Washer Bottle!!! anthemmaster Bravo / Brava 3 06-03-2004 16:44
