Technical Clutch and accelerator pedals sticking
StumpyWitch
Has anyone come accross this problem before? :confused:
I have a 2002 Punto 1.9 JTD Dynamic.
When I raise the clutch pedal it gets stuck just before it reaches the very top, but also at the same time the accelerator pedal feels very hard to push. Then a split second later the clutch pedal will release it's self and the accelerator pedal is back to normal. Any ideas????
Try a squirt of WD-40 on the pivots bearings see if it improves thats the easy fix! If that don't work sounds like something is catching somewhere all you can do is check the operation of cables, linkages, pivots hydraulics?
