PoorlyPunto
- Feb 14, 2021
- 20
- 6
Hi all,
Is anyone familiar with this problem? The rubber strip above the front windscreen has a portion missing in the corner. Only noticed it a few weeks ago when I was washing the car so I've no idea what's happened to it or how long it's been like this. There's no water leaking into the car but it seems to be causing the roof to rust and the paint is peeling quite badly.
My question is where can I obtain a new seal? ePER says the part number is 46819780 but when I search for this, some (but not all) listings show a completely different seal (see here). The seal on my Punto has a 'T' shaped profile and the width is 17mm. I can only find one 5 door MK2 being broken for parts on eBay and from the pictures it seems that has the same problem, the rubber seal doesn't span the full length of the windscreen. Ideally I just want to purchase a new one but as there's no UK sellers I need to be sure I'm buying the correct part as I won't be able to return it and in the meantime the rust is getting worse.
Any help greatly appreciated!
