Technical Replacing valve cover gasket. Anyone know the torque specs?
gdourado
Hello,
Another job I will be tackling on the HGT at the same time of flushing the coolant, is to replace the valve cover gasket as it is currently leaking a tiny bit of oil.
Does anyone know the torque specs to tighten the bolts on the valve cover once the gasket is changed? I don’t want to run the risk of over tightening.
Thanks.
